Acer 5920 headphone jack problem
  • Engineer2k2
    • Aug 2009
    • 5
    I am facing a typical problem -
    In my Acer 5920 audio is working fine while using internal speakers but when I insert a Headphone jack in Headphone socket (Black) and select Headphone from the auto popup dialog - sound starts playing in left headphone only.
    The right channel does not sound - but again when I pull out the headphone jack both channels start playing through the internal speakers.
    What may be the cause ? Since the socket seems OK physically.
    Please Help.
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Acer 5920 headphone jack problem
    try headphones in other amp or tv. make sure they good.
    • Engineer2k2
      • Aug 2009
      • 5
      I have four different headphones which are working with my other computer as well as other devices such as mp3 player and external firewire sound card.
      The problem is only with my laptop - that too just the right channel of my headphone socket.
      • t.j.
        • Apr 2010
        • 383
        • canada
        possible cold solder! wiggle it around get any buzzen or hissing?> ya i know asken if work in other device was dumb question, but haD to be asked!
        • Engineer2k2
          • Aug 2009
          • 5
          Already tried - doesn't seems cold solder - may be some discreet component failure in the headphone circuitry. Thanks !
          I need PCB layout diagram so that I can troubleshoot myself. Further the socket is of special type - it has provision for sensing jack as well as optical LED at the end, since it works as spdif/digital out also. I also want to know whether I can get the specific socket in the local electronic market or have to approach ACER - if found defective.
          • Engineer2k2
            • Aug 2009
            • 5
            Re: Acer 5920 headphone jack problem [SOLVED]
            Last week I opened my Laptop and found that there was no dry soldering and the headphones socket's pin were all intact. After inserting a headphone jack I checked the pins on the board and found that both channels signal was present (i.e. left and right) at the pins on the board where the jack was soldered.
            Then I realized that there is some problem with the right terminal inside the socket and used a bent pin to just lift the leaf inside the socket a little bit so that it can come in proper contact with the headphone jack.
            VIOLA!! the headphone started working with both channels working.
            • dj_ricoh
              • 2073
              • uk
              it take 2-3 min to unsolder a audio port ; just change it
              • jtamad44
                • Apr 2013
                • 145
                • israel
                agreed
                  Acer Aspire A515-57-5920 Notebook 5 Specification for Upgrade or Repair
                  This specification for the Acer Aspire A515-57-5920 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-57-5920 boardview and A515-57-5920 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-07-2024, 07:20 AM
                • paparazzo79
                  3.5 mm headphone jack missing
                  by paparazzo79
                  Hi guys,
                  I purchased used MSI GE 73 Raider laptop used from a guy.When laptop came home I noticed that there is no "golden circle connector" on the headphoner jack (pic below).
                  I contacted the seller, he told me like it was there and it probably fell off.
                  I am not dumb, is he lying to me or it is possible that in the shipping it really fell off?
                  Oer laptop is missing whole connector.
                  The headphone jack works normally,I have tested it with headphones....
                  05-20-2025, 08:48 AM
                • fmajbour
                  Acer Nitro 5 model A515-51 keyboard problem
                  by fmajbour
                  I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                  Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                  i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                  I have check the keyboard connector on the mainboard every thing looks ok.
                  Then i replaced the keyboard with new one ......same problem exact same keys problem.
                  I need your advice if anyone face...
                  11-13-2023, 09:50 PM
                • ahmarzo
                  Acer TMX314-51 laptop battery problem
                  by ahmarzo
                  I have acer laptop tmx314-51 with part no 6050A3020501.
                  The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                  But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                  I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                  The schematic is not available...
                  04-11-2025, 09:14 AM
                  Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                  This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-07-2024, 05:00 AM
