Board problem
  • lord
    • May 2011
    • 319
    • Croatia
    Board problem
    It is a desktop board VB7001, i have 30 pcs of them with 2 kinds of error.
    First one is that board boots but: i push the power button, bios code stops at 00, the i hit the reset button and the board boots. I changed VIA VT1211, ICS 88060 and 6535CBZ.
    Second error: there is no nortbridge voltage, but i didn't have a chance yet to strugle with it. Hopeing there will be some help on the first error....
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Board problem
    What type of bios is it? (I.E. Pheonix, Insyde...)
    Did you try flashing the bios?
    Get some pics please!
    There might be a bad voltage regulator for the northbridge chip.
    -Ben
    Muh-soggy-knee
    • lord
      • May 2011
      • 319
      • Croatia
      Re: Board problem
      Still didn't had a chance to olay with it. When i do, i will post then news.
      Thank you for your reply!
      • huj3r
        Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
        by huj3r
        Hi there!
        I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
        Photo of the situation after the black shadow dissipates:
        After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
        I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
        > This indicates HFR Communication error. [ HFR Communication...
        08-15-2023, 10:55 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
