Board problem
  • lord
    • May 2011
    • 319
    • Croatia
    Board problem
    It is a desktop board VB7001, i have 30 pcs of them with 2 kinds of error.
    First one is that board boots but: i push the power button, bios code stops at 00, the i hit the reset button and the board boots. I changed VIA VT1211, ICS 88060 and 6535CBZ.
    Second error: there is no nortbridge voltage, but i didn't have a chance yet to strugle with it. Hopeing there will be some help on the first error....
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Board problem
    What type of bios is it? (I.E. Pheonix, Insyde...)
    Did you try flashing the bios?
    Get some pics please!
    There might be a bad voltage regulator for the northbridge chip.
    -Ben
    Muh-soggy-knee
    • lord
      • May 2011
      • 319
      • Croatia
      Re: Board problem
      Still didn't had a chance to olay with it. When i do, i will post then news.
      Thank you for your reply!
      • PNI E.
        Dyson v15 problem with the dust detector board
        by PNI E.
        Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
        10-02-2025, 10:18 AM
      • huj3r
        Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
        by huj3r
        Hi there!
        I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
        Photo of the situation after the black shadow dissipates:
        After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
        I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
        > This indicates HFR Communication error. [ HFR Communication...
        08-15-2023, 10:55 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
