DV5000, Charge ok, no power on
  • nemesys79
    Technician
    • Oct 2011
    • 10
    • Italy
    Hi guys,
    i'm trying to bring back to life this notebook.
    Motherboard is quanta qt8
    I have standby power,battery charging ok, but when pressing power button only a fast single led flash, then completely dead, no fan at all.After checking the entire mobo, i found PC45 to be very hot, i replaced (it's a 1U/10v), still hot.
    It's on pin 47 of ISL6265HRTZ-T (VCC).
    Thinking about a bad cpu, but i don't have a spare one.
    Any ideas to find culprit?
    Thanks in advance, have a good weekend!
  • nemesys79
    Technician
    • Oct 2011
    • 10
    • Italy
    Re: DV5000, Charge ok, no power on
    Please, anyone can help me?
      That cap could only be hot if it had failed or 5V was too high or unregulated - check it has 5V across it.
      • dj_ricoh
        • 2073
        • uk
        @nemesys79 can you upload the full schematic? can`t find it.plzz
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • ipatch
          troubleshooting microsoft surface pro 4 no power no led charge light
          by ipatch
          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
          10-05-2023, 11:59 AM
        • proxneo
          iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
          by proxneo
          Dear reader
          TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
          I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
          12-01-2023, 04:14 AM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
