choosing right laptop fuse
  • fabiog
    • Jul 2011
    • 102
    Hello
    I have a fujitsu esprimo V5535 with what seems to be blown fuse (multimeter gets out of range error on both ohms and continuity test).
    It has this fuse:
    http://search.digikey.com/us/en/prod...87TR-ND/700828
    5a 125v SMD.
    I have an older Acer board with a different fuse 6.5a 32v:
    http://parts.digikey.com/1/parts/697...16ff6-5-r.html
    Would this even work or be just plain unsafe?
    Thanks for any comments.
  • fabiog
    • Jul 2011
    • 102
    Re: choosing right laptop fuse
    I also have a spare 10A 125v :
    http://search.digikey.com/us/en/prod...91TR-ND/700832
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Voltage as long as it is rated for more than where it is used does not matter the amperage is the crucial thing.
      Are you testing off the board? or at least one end lifted
      • fabiog
        • Jul 2011
        • 102
        Tested on and off the board and get out of range ,laptop has another fuse by battery connector 7A and that tests fine.
        On page 29 of the schematic the fuse is by the DC jack and it is labelled F1.
        • 999999999
          • Sep 2006
          • 774
          I am doubting that a blown fuse is the only problem, probably some other fault caused it to blow. I would not use a 10A fuse there, except that if there is some other fault bad enough that it would cause you to scrap the laptop, then it would be nice to avoid the extra expense of buying more parts for it, so what I would do is pull out all components non-essential to get it to post and access bios menus (no HDD, only one memory module, etc, to decrease chances something you can unplug is the fault point), then solder in the 10A fuse you already have and see if the laptop works.
          If it works, then I'd add back the removed components to see if it still worked and if it does, THEN I'd order the right value fuse for it. I would not desolder a fuse off another board to use, repetitive thermal cycling of surface mount fuses can compromise them and lower their current capability.
          • fabiog
            • Jul 2011
            • 102
            I tried the 10a fuse and it's working fine ,the laptops owner has a universal power adapter and the tip was slightly loose and not connected correctly to the adapter and I suppose that's why the fuse blew.
            Now I have to order the 5a fuse ,
            Thanks for the help.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Great news - please can you update your profile with at least country and mains voltage.
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
              • jshhh
                Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                by jshhh
                Hi guys,
                I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                Anybody know how to remove this type of fuse?
                (The fuse is toward the bottom of the image labeled F2)...
                06-17-2025, 01:35 AM
              • Babbar
                by Babbar
                04-12-2024, 01:12 AM
              • drykid
                Matsui 175S microwave fuse replacement
                by drykid
                I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                12-21-2020, 01:15 PM
