MacBook fan question
+ More Options
Posts
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    OK, so I found a handy program for my MacBook called smcFanControl.
    By default, the MacBook fan starts at 1800RPM (silent). Then the bottom of the computer gets REALLY hot because the heat is spread to the plastic, even though, (for example), during a long web browsing session the CPU doesn't get hot enough to ramp up the fans.
    The max speed of the fan is 6200RPM. Now, while the program can't really set the fans exact speed, it can set the minimum speed. And since the laptop isn't usually hot enough to make the fan go to full, this technically gives me a way to make the fan spin at whatever speed I want.
    Right now it's set at 4500RPM minimum. So far it hasn't gone any higher than that. Then again, BCN isn't exactly CPU intensive.
    My question is: Is it better for the computer to leave the fan on low, because it puts less wear on the fan, or is it better for the computer to make the fan run faster because it gets significantly less hot inside? Also, does the fan spinning faster use more battery life?
    Thanks!
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: MacBook fan question
    Consider shimming the GPU and CPU with a bit of copper or re-applying thermal grease and OR cleaning the heatsink and fan...
    • Aikiotto
      • Oct 2011
      • 30
      Having the fan run at full speed has a good side and a couple of downsides , it keeps your lappy cooler yes , but it also wears the fan quicker , makes it noiser and transform your machine in a mini vacuum cleaner , wich means it will draw more dust in and youll have to clean those airducts more regularly , so depending on your particular model and skills it could be more of a hassle than a solution.
      Aiki
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Thanks for the info guys!
        As fas as noise, I don't mind the slight increase in noise because it's not absolutely silent in class or on the bus.
        A little more dust in my computer is not a big deal. These MacBooks are easy to work on; I've done it multiple times.
        About the fan wearing faster, that's the only issue. I guess I'll make it default to 3500RPM that way it won't run so fast but still cool it better
        • Sparks88
          • Sep 2011
          • 110
          looking on fleabay the cost of fans for macs is very expensive and particular models seem to have a high failure rate, does yours have 2 fans? if you are getting noise one could be on its way to fan heaven (the right hand side one seems to be favourite)
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            It has a single fan.
            It's not at all noisy, the fan is just fine...
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • obelix24
              A2941 Macbook air 15” - 5V 0a
              by obelix24
              I’m working on one macbook air 15” m2 that was water damaged.
              keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
              i’ve put macbook in shelf and order new screen so i can fully repair it.
              Now i got the screen and macbook stays at 5v 0a.
              i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
              i don’t have schematics so i don’t know where to start can someone help me?...
              03-27-2025, 01:19 PM
            • Kush679
              MacBook Pro M1 Activate Mac
              by Kush679
              Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
              Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
              06-20-2025, 09:43 AM
