max8724 ic
  • scooby01
    • Dec 2011
    • 28
    • uk
    max8724 ic
    can anyone tell me where to buy max8724 ic's in the UK. Some in china from ebay but none in the uk. Tried cpc and rs but none?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: max8724 ic
    IIRC it is a proprietary chip.
    ebay is your only real choice...
    sigpic
    (Insert witty quote here)
    • b700029
      Banned
      • Sep 2010
      • 640
      Re: max8724 ic
      It's far from proprietary if they even offer the option of free samples...
      http://www.maxim-ic.com/datasheet/in...p/id/3767/t/or
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Re: max8724 ic
        http://uk.mouser.com/contact/
        • DXseekerMO
          Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
          by DXseekerMO
          Hello everyone!
          Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
          I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
          Yes
          0%
          1
          All backlight strips are the same quality
          0%
          1
          No
          0%
          0
          12-16-2021, 03:58 PM
        • Topcat
          Windows 10 Enterprise - From Ebay...
          by Topcat
          https://www.ebay.com/itm/324996085177
          You find these on ebay all the time. Seller feedback is good in regards to them being legit...but I'm still leary. Anyone with experience with these? Seems quite a few around here are running enterprise; and unless ya'll are stealing the keys from your employers, where are you getting them?
          03-02-2023, 03:16 PM
        • neilc6
          Sold Sharp LC-50LB370U Board on Ebay - Return Requested
          by neilc6
          Sold this board on ebay with this warning in the description and pic of working TV.
          "Pulled from a TV with a damaged panel. NO REFUNDS.
          This model suffers from LED backlight failures. Make sure your backlights are working before replacing boards. Symptom is TV turns on and off with no backlight or a flash of backlights."
          Ebay Return Request
          Reason for return - Doesn't work or defective
          Details - Powersupply board has sound,but verry dark screen.I would like to return,You send for me another one. Thank You.
          With ebay, if...
          07-16-2021, 04:00 PM
        • myth77
          how do you resolve problems with ebay (and other shop) scammers!?
          by myth77
          When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
          So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
          First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was...
          09-02-2022, 04:53 AM
        • double_DD
          Philips curling iron - is this a common AC cable?
          by double_DD
          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
          08-18-2025, 10:04 AM
