VPCF12E1E works but screen only on external
  • sebuncle
    • Jun 2010
    • 46
    • France
    hi ,
    i have a problem with a VPCF12E1E , it start well and go to windows , but I have an external screen display only
    i tried other screen , screen cable and inverter but no change it's same.
    there's certainly fuse on the motherboard where is it ? which voltage should be on this fuse ?
    M931 MBX215 REV 1.1
    thank you for your help
    JOVY RE7500
  • Sparks88
    • Sep 2011
    • 110
    Re: VPCF12E1E works but screen only on external
    if you can use an external monitor the video switching chip is detecting the monitor so you need to try trace the video signal path, i would start at the lcd connector block on the motherboard and trace backwards from there looking for bad solder joints.
    • marcellodj
      • Nov 2010
      • 99
      Reflow gpu.
      • Ado02
        MacBook Pro A2159 - No Display / Works on External Screen
        by Ado02
        I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
        Please see the attached image.
        I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
        Can anyone suggest where to go from here?...
        01-12-2023, 03:35 AM
      • eurowill
        a2141 820-01700 internal display not working / external works
        by eurowill
        Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
        Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
        07-23-2024, 10:06 AM
      • Yehuda170
        ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
        by Yehuda170
        original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
        replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
        now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
        with original broken screen i can see in device manager touch screen in human interfaces
        but with the new screen it's not showing in device manager
        is it lenovo blocking it? is it driver missing?
        I²C is a headache
        07-14-2023, 01:29 AM
      • ahoonid
        MacBook A1990 vertical stripes on external screen
        by ahoonid
        Hey everyone,
        I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
        The board is neat. Not opened before for sure. Just a little dust, nothing more.
        Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
        Today, 08:54 AM
      • survivalbloke
        HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
        by survivalbloke
        SN: 8CG0213H8W
        ProdID 3C311UA
        This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
        05-08-2025, 12:21 PM
