Laptop Damaged USB Port - Missing Component
  • graham01
    • Oct 2011
    • 92
    Hi everyone, I recently dropped my laptop (Toshiba R630-13R) while it had a USB stick in it, it landed on the USB stick pushing it inward and removing a tiny surface mounted component behind it. Sods law eh?
    From looking at the tracks on the board, it connects the 5V VCC to the GND. Can anyone help me identify what it is? I *think* it will be a surface mounted capacitor.
    I am not that bothered about getting the USB port working again, but this board also connects to the internal speakers, and the audio outputs, both of which do not work any more, which is quite annoying.
    I have uploaded some pictures of the board and the damage, please see below;
    http://i42.tinypic.com/a48w03.jpg
    http://i41.tinypic.com/17y0ch.jpg
    Thanks for reading! Regards
    Re: Laptop Damaged USB Port - Missing Component
    Is this a separate board just for the USB and audio?
    If you look at other USB ports on the motherboard, what component is used there?
    • graham01
      • Oct 2011
      • 92
      Yes it is a separate board, I did some voltage checks on it when it was turned on. All pins on USB are dead, strangely audio does have power going to it, all pins connecting to the internal speakers are about 2.3V.
      I tried to look at the USB connector on the other board and that just confused me more, there are 2 surface mounted components connecting the VCC to the GND. They are both pink in colour, one is the same size as what you can see on the pictures (closest SMD to the missing component) and the other one is about 3x the size.
      Regards
        Regards
        Ah pink is probably an ESD protection device. It's designed to prevent you from zapping the laptop's motherboard if you touch the ports.
        2.3V (DC) would quickly fry the speakers are you sure about that reading?
        • graham01
          • Oct 2011
          • 92
          Oh dear, yea I just checked again, there is 4 cables, 2 for each speaker, they read 2.32V, 2.32V, 2.28V 2.30V.. I am guessing there is something not quite right then..
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            If it's on a seperate board and you can't get it working again it would probly be easy to source the little board on eBay or something...
            • graham01
              • Oct 2011
              • 92
              Yea I found one on eBay but only in America with a 4 week wait I also can't afford it yet.. I really don't want to go that long without music!
              regards
              • mariushm
                • May 2011
                • 3799
                You can use one of these as a temporary solution :
                http://www.amazon.com/External-Chann...3133025&sr=8-1
                Use amazon.co.uk if you're in UK (or Europe)... assuming it since that Toshiba model number looks like an European one. Just search for "usb sound card" ...
                Though a bit of warning - the sound quality of these usb toys is not that great.
                  Measure the voltage across each speaker, it should be less than 0.1V.
                  • graham01
                    • Oct 2011
                    • 92
                    Haha, I know nothing about electricity.. one is 0V the other is 0.01V. Why is is 2.3V compared to the ground? Is that just nonsense?
                      Voltages across a device are what the device sees.
                      MOST but not all devices on the motherboard are relative to the ground. But in this case, it turns out it is cheaper to make one end more positive and one more negative, rather than make one side positive or negative and one side ground; it reduces the cost and means you don't need a second (negative) supply.
                      • graham01
                        • Oct 2011
                        • 92
                        That is crazy and confusing, i wish i knew more about electronics.. i can solder anything, but i don't have a clue what it does lol.
                        Anyway, how can I fix my USB problem? And why has that component removed my sound? Do those ESD's have a +ve and -ve? I tried to solder one on but it didn't fix anything
                          I think you should check if the audio jack is broken. Maybe it is being held in "headphones mode" where the speaker output is muted?
                          • graham01
                            • Oct 2011
                            • 92
                            I thought I had a driver problem first, my only audio devices the laptop can recognise is HDMI out, the volume control on windows has a constant X over it and placing the cursor over it says 'No speakers of headphones plugged in', clicking the speaker icon brings up a 'Diagnosing problems' window which doesn't find anything.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              last time I had a usb port damaged on a laptop, I found a dead board of a similar model and literally unsoldered the usb port from the bad board, and replaced it on the working laptop. worked too, 'twas a old P4 dell inspiron desktop cpu laptop
                              • graham01
                                • Oct 2011
                                • 92
                                http://i41.tinypic.com/24y8jr7.jpg
                                managed to solder a similar looking component to it.. I wasn't really expecting much, it was only to see how easy it would be. Even without this component, shouldn't I still be seeing 5V on that rail? There are a few rails showing 5V around that area connected to that 'AQR' chip, but the rail connected to the VCC is cold.
                                • graham01
                                  • Oct 2011
                                  • 92
                                  I don't believe it, I am now getting 5V on that rail (however not on the pin, think it is broken) and my speakers are working!! How is that even possible? I thought it didn't work in the previous post because I only had my hard drive plugged in, and when I connected the battery there was no life. Unbelievable!!
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    That part probably doesn't have anything to do with sound which means you might have another problem.
                                    The 5v is for power.
                                    There are no sound related IC chips on that card that need power. [Unless they are on the other side.]
                                    That means it's just a pass-through from somewhere else to the jacks.
                                    The 5v for USB is to power things you plug into USB.
                                    That usually has it's own regulator and rail. [To protect the motherboard from bad USB devices.]
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • Evil Lurker
                                      Warranty Voider
                                      • Feb 2011
                                      • 454
                                      The component that broke off the board is a multilayer monolithic ceramic capacitor. It is used for decoupling purposes I am guessing. Capacitance of the original component could have varied from anywhere down in the pF range to around 1uF depending on size and construction, perhaps .1 or .01uF... who knows.
                                      • graham01
                                        • Oct 2011
                                        • 92
                                        Thank you for all your responses!
                                        PCBONEZ: Yes there is more components underneath the board
                                        Evil_Lurker: Thanks, so do you think the component I replaced is doing its job then? I just finished repairing the part, just created a connection between the pin and a component on that rail.
                                        I just did successfully did the ultimate test of playing music through my laptop speakers from an external hard drive connected through that USB port, worked like a charm.
                                        My repair jobby: http://i39.tinypic.com/2j3lke0.jpg
                                        Thanks for all your input guys
                                        • Ritchie_Uk
                                          Sony PS4 component Missing, near the HDMI Port
                                          by Ritchie_Uk
                                          Hi there
                                          A Sony PS4 came in for "No Video" and it seems there is a component Missing, near the HDMI Port.
                                          The Component circled in Red
                                          1. Was this just a Component Missing from Manufacture please?
                                          2. It is a straight forward Port Replacement, or do I need to be aware of anything else?
                                          3. Any Schematics or Board Views available?
                                          Any Advice is greatly appreciated.
                                          Stay Safe !!...
                                          05-22-2023, 06:12 PM
                                        • maybepanic
                                          HP Probook 450 g5 Liquid damaged USB-C / Display port switcher
                                          by maybepanic
                                          Hey,
                                          I've got a liquid damaged HP Probook 450 g5.
                                          There was a lot of corrosion around the Paradetech PS8743B B1 chip, plus what looks like heat damage from a short. There are no schematics available for the board, nor could I find any schematics from paradetech for the USB-C / Display port switcher.
                                          Is there anything else I can do to increase my chances of fixing the board apart from checking for shorts around the ic and replacing it?
                                          Attached some pics of my liquid damaged board, closeup of the cleaned ic and a pic of a good board I found online.
                                          Thanks!...
                                          06-07-2023, 04:30 AM
                                        • Belmoto
                                          Asmedia ASW1142 usb 3.1/C not working properly on msi z170a m7
                                          by Belmoto
                                          Hi there,
                                          Recently I had a problem with my msi z170a m7 mobo usb c/3.1 port,
                                          The port connects normally but when I transfer data it transfers with full speed (from the pc to the device I'm sending to) but it does not receive with the same speed, to make it simpler, if I plugged a wifi adapter to it, I can upload with full speed but I can't download with the same speed, but if I connected the adapter to different port it downloads at full speed.
                                          I'm not sure if it's a HW problem or a SW one,
                                          I have MSI z170a m7, with modded bios to install coffee...
                                          05-20-2024, 03:06 PM
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
