CQ510 Blinking Light dan charging output not normal
  • arieshenri
    • Jul 2011
    • 10
    Hi there, I am having problem with hp Compaq CQ510... everytime plug in power adapter, suddenly D12, D11 light on blinking once each. Then off. Then blink again one each then off. Power button does not work at all. Check output voltage on charging pin comes resulting less than 5 volt. then everytime the lights on then the voltage becomes less than zero then lights off come again to 5 volt...
    need help please
  • arieshenri
    • Jul 2011
    • 10
    Re: CQ510 Blinking Light dan charging output not normal
    Tried checking on TPS51124... VIN got normal 5V.. but V5FILTER HAVE 5 VOLT, THEN WHEN THE LED LIGHTS BLINKING ONCE.. THE VOLTAGE DROP THEN GOES UP NORMAL AGAIN... SAME THING HAPPEN WITH VOUT1 AND VOUT2... HAVE GOOD VOLTAGE OUT BUT WHEN LED BLINKING DROP DOWN THEN NORMAL AGAIN. IT HAPPENED JUST WHEN PLUGGED IN CHARGER, BEFORE PRESSING POWER BUTTON. POWER BUTTON PRESSED DOES NOTHING AT ALL. ANYONE CAN HELP ?
    • xaviero1412
      • Apr 2009
      • 56
      try check CL or PL, there are high-voltage capacitor about 1nf
      maybe they are shorted...
      • 1centchips
        Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
        by 1centchips
        I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
        The laptop is just out of warranty.
        The laptop continues to freeze randomly with the blinking amber charging light.
        What could be possibly wrong with it?
        I have also disable armoury crate in bios.
        12-17-2024, 05:18 PM
      • esqmooo
        HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
        by esqmooo
        Hello everyone.
        This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
        Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
        Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
        I tried long pressing on the power button, after several seconds it would go off then when the button is released...
        03-11-2025, 03:57 PM
      • esqmooo
        HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
        by esqmooo
        I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
        03-07-2025, 05:55 AM
      • YasaCh
        Sony kdl 40p5500 red light keeps blinking 3 times
        by YasaCh
        Hello...
        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
        i opened the back cover no sign of damage on the powery suply or motherboard
        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
        07-07-2025, 11:53 AM
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
