connector identification needed
+ More Options
Posts
  • skywalker
    • Jul 2010
    • 33
    I am looking to source this connector, I have endlessly tried to search for the part but to no avail. this connector is widely used for connecting laptop modems Ethernet and bluetooth modules
    Could anyone help me into sourcing this part
    For size comparrison i have taken this picture next to a cpu
  • gretti
    • Jan 2011
    • 20
    Re: connector identification needed
    Looks like the standard connector from a laptop modem. Just cut one out of your nearest dead laptop. You know you can take the pin out of the connector and solder your wire to the pin, then just stick it back into the connector. I'm just saying because it sounds like you broke one.
    • skywalker
      • Jul 2010
      • 33
      Yes this is missing a cable in the picture , I need about 100 of these connectors , Does anyone know where to purchase these from.
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
      • 5mall5nail5
        Help identifying connector for ASUS 4090 Strix RGB LED connector
        by 5mall5nail5
        Hi All -
        I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
        Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
        05-04-2025, 07:47 AM
      • michhak
        Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
        by michhak
        Hi guys,
        i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
        It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
        11-17-2021, 05:45 AM
      • m1ch43lzm
        70mai Dash Cam A510 - help identifying connector on camera module
        by m1ch43lzm
        Hi everyone
        I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
        The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
        I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
        05-11-2025, 06:02 PM
      • reformatt
        LCD Connector identify or source
        by reformatt
        Trying to identify where to source the LCD connectors on the motherboard side for a HP 14-cf2051la. This one came in with liquid damage to the connector and the flex cable. It appeared to clean up ok, however customer says that display blanks out intermittently. It's a 30 pin EDP flat ribbon cable on motherboard side. Believe it to be a HEDWIG-6050A3155301-MB-A01 motherboard.
        I've stolen the connector from another HP motherboard which matches up but it's not the best since it's been kicking around my donor pile for a while. This connector is different to most flip type ones I have...
        03-25-2024, 08:29 PM
