Lenovo G560 works on battery only
  • protools_operator
    • May 2011
    Hi everyone this is my first post but i gathered a lot of information in time from this amazing forum.
    I'm trying to fix a faulty mainboard of an IdeaPad G560. It was coffee-damaged and the keyboard didn't functioning good. After replacing it I noticed that the G560 works only on battery.
    What should I check for? where do I start?
    The battrey is not charging nor DC connected without battery doesn't power computer.
    I cleaned all the corrosion ofcourse.
    Laptop gets DC voltage correct until the motherboard so it's not the DC jack cable.
    Battery pins get's very low voltage (about 0.4).
    I don't know where to continue, it seems like the G560 doesn't recognize that it is connected to DC.
    When the DC is connected and the battery doesn't there is a low volume noise when that I hear coming from the motherboard while it's off ofcourse and HD disconnected. Also there is a low volume noise from the Ac/DC adapter. When I connect the battery and the DC is in there isn't any noise like this.
    Would like some help.
    I own a soldering station for SMD and also a rework station.
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: Lenovo G560 works on battery only
    Better way is to remove it apart and check mobo for any corrosion with magnifying glass (micro cracks or bad solder points) in power supply section. Maybe some mosfet transistor(s) is bad and needs to be replaced.
    Laptops and computers repair.
    • protools_operator
      • May 2011
      Thank you for the quick answer gabi.
      I must say that I used to study electronics back in highschool and I know the basics but I'm not a pro.
      I really appreciate any help and I think it's a great forum.
      I cleaned the power section again with anti corrosion liquid.
      I tried to measure resistance in the power section mosfets, all the mosfets seems fine except one that i'm not sure about it, it measures gate to source - 197KOHM, source to gate - 0.200MOHM, drain to gate doesn't show any reading and when measuring drain to source I get 186KOHM after waiting that the resistence will be stable (going from about 177KOHM one 0.1KOHM at a time until gets to 186KOHM.
      :EDIT: I checked closely and I saw that between the source and the gate there is a capacitor so it may not be the problem.
      I checked the battery leads it is:
      GND GND POSITIVE POSITIVE POSITIVE (PLASTIC) POSITIVE POSITIVE.
      The 2 POSITIVE in the most right shows stable 8VDC when connected to the DC JACK.
      THE OTHER 3 POSITIVES shows a reading that changes every second between 1~ and 2~ VDC.
      also I checked the power chip (RT8206B) for voltage from the VOUT-3.3V and VOUT-5V and it was unstable.
      what am I missing here?
      Thanks,
      -Noam
      • protools_operator
        • May 2011
        Anyone has experience with this problem?
        Thanks,
        I wait only for answers from the forum before I touch the laptop again
        Hope to get any idea
        • ferryvanhot
          • Aug 2011
          • 7
          Thanks,
          is the problem solved??
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Zibbo
            Lenovo T470P NM-B071P not charging, 20 volts on positive +ve battery terminal
            by Zibbo
            Lenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
            Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals.
            12-27-2024, 12:20 AM
          • ZixuTech
            Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
            by ZixuTech
            Hi Guys, a weird case here.
            This laptop came with damaged hinges, but no liquid signs.
            It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
            I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
            I have replaced bq24780S battery charging chip, no difference.
            With a connected new battery,...
            04-03-2022, 04:03 AM
          • mrkmpn
            Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
            by mrkmpn
            Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
            This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
            03-13-2024, 01:54 PM
