I have an HP g61 laptop here and the video display goes black. The video card is working because it is fine on an external monitor. I have replaced the inverter and still the same. It appears like a loose connection but I have checked and re checked but can't find one. The only connection I didn't check was the the ones on the lamps (ccfl)? I did not pull the lamps. Has anyone seen this problem before and any suggestions?
HP G61 Screen goes black
Re: HP G61 Screen goes black
Well , do you see anything on the screen when you lighting up by a flashlight? If you see something then there is a backlight problem , but if there's nothing you might search on the mobo and you have to look closer to GPU.Laptops and computers repair. -
Thanks gabik111. No there is no image that I can see when I light up with a flashlight. What to look for on the mobo? Could a driver cause this condition within the GPU?Last edited by davg; 05-08-2011, 09:29 AM.Comment
Depends on what conditions were during laptop using (high temperatures , extreme pressure on the housing) I can say that are GPU balls. Try to push the GPU or heat it up (not overheat) during startup. Propably you will get something on LCD. Also find lid switch and check it out. This is not backlight issue (no image on screen).
I can say for 99% this is GPU for reballing or exchange (you got ATI graphic so I don't think you need to replace it) IMHO.Laptops and computers repair.Comment
Thanks again gabik111 I am not sure how to respond to this post as I am not sure what reballing is or how it is done? In my search I found that it is the process of re soldering on the chip? Is this a common problem? Sounds complex? I will look for the lid switch and hope it is the problem?Depends on what conditions were during laptop using (high temperatures , extreme pressure on the housing) I can say that are GPU balls. Try to push the GPU or heat it up (not overheat) during startup. Propably you will get something on LCD. Also find lid switch and check it out. This is not backlight issue (no image on screen).
I can say for 99% this is GPU for reballing or exchange (you got ATI graphic so I don't think you need to replace it) IMHO.Comment
Yes , reballing is replacing solder balls under BGA chip. Special tools are required to do this. Some peoples trying to repair damaged balls using heat gun or hot air soldering station but this partially helps. Proper repair contains chip removal , cleaning pads , install new balls on chip and solder to mobo (best way to use infra-red station).
Maybe this switch will solve problem .Laptops and computers repair.Comment
Ya to complex for me Thanks gabik111. Question; when I open and close the lid the puter sleeps and awakes which would be an indication it is working if this is the switch you refer to? By changing the function of the switch in the power setup would this eliminate the switch? If I disassemble the thing the video comes back but after re-assemble it's gone again I was suspecting a bad connection on the ribbon cable to the monitor? but than that being the case the screen would light up bright? I don't know if I am making any sense here?Yes , reballing is replacing solder balls under BGA chip. Special tools are required to do this. Some peoples trying to repair damaged balls using heat gun or hot air soldering station but this partially helps. Proper repair contains chip removal , cleaning pads , install new balls on chip and solder to mobo (best way to use infra-red station).
Maybe this switch will solve problem .Comment
It can be bad ribbon cable. But also when you asseble everything motherboard can deformate and it can cause bad connection (or solder point) on mobo. Remove mobo and connect everything to get it works. I had similar problem in vaio laptop. I found that add small washer in one point put life to the laptop.
But if this is a ribbon cable it will be easy to fix.Laptops and computers repair.Comment
Thanks again gabik111 I have to do more investigation. Having an intermittent problem makes the task more difficult.It can be bad ribbon cable. But also when you asseble everything motherboard can deformate and it can cause bad connection (or solder point) on mobo. Remove mobo and connect everything to get it works. I had similar problem in vaio laptop. I found that add small washer in one point put life to the laptop.
But if this is a ribbon cable it will be easy to fix.Comment
Thanks skywalker you have obviously read the post above, any suggestions? As I indicated above I have had the thing apart several times and each time I get video. I have re-assembled the thing and still had video but for reasons beyond me it goes black and the only way to get it back is to take it apart again?
At first if the lid was held in a certain position it was fine but if the lid was moved it went black, move it back it was ok again. I guess it could still be a broken cable? And I don't have one to try?Comment
If you got multimeter you can remove ribbon cable and try to measure it - every line.
And back to skywalker post - this is not obvious. LCD is using diferrent driver than external monitor and sometimes when external monitor is working - LCD is not, and then you have to find what is going on...Laptops and computers repair.Comment
skywalker is correct. The GPU, if the problem, wouldn't properly POST so you wouldn't get a video signal on the LCD or external. The LCD itself is bad. I had one in my shop just the other day that I had to replace the screen.Comment
But LCD itself got two circuits. Backlight and LCD integrated drivers (that driving vertically and horizontally all pixels) so in this case both died in one second...Laptops and computers repair.Comment
i have a hp g61 in which screen went black after some time so i replaced the inverter but there was still a problem so i decided to change the cable that also didnt work after going through the forums i thought it was a gpu issue so i changed the mobo still the result is same the only change is now when the screen goes black qand if i close the lid and open it back i get display for few seconds it is confirm that problem is with screen but not sure whether it is back light or the screen itselfComment
YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
I also changed the screen because the PC fell and the screen was broken.
I changed the battery with a new and original battery.
I also had corrosion/oxidation on the... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared
I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
by DaniKHi everyone,
I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
Laptop came in for a SSD upgrade, took everything apart to install the SSD.
Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
Symptoms are:
- random black screen after displaying Acer logo... -
by turmixHello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
During another reassembly, I made a mistake, and...-
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
