Dell Latitude d400 USB power problem
+ More Options
Posts
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    great. my dell latitude d400 rear usb port crapped out on me.
    I recently bought a new mainboard for it... the old one had the 855 usb data failure, and i bought a used mainboard for it.
    the warranty expired 4 weeks ago and now i have a problem. the rear usb port is not getting power. it gets data just fine.
    any advice? I removed the mainboard and the soldering APPEARS good... but the usb joint is covered in yellow flux-like crap so i do not have the best view.
    This laptop gets used a lot and one usb port down is not good. I do not have the funds for a new laptop so i have to make this work... I love it otherwise, but this is driving me nuts.
    sigpic
    (Insert witty quote here)
  • seanc
    • Nov 2008
    • 1319
    Re: Dell Latitude d400 USB power problem
    Poke around the previous board and the current one to see if you can find the source of the problem?
    • Scenic
      o.O
      • Sep 2007
      • 2642
      or run a jumperwire from another 5V source directly to the USB port.. with a picofuse in series for protection
      did that once when a USB port fuse burnt up so violently it FUBAR'd the traces. ran a jumperwire with a picofuse from the HDD power pins to the USB ports.. (on the motherboard connectors.. not soldering it to the HDD itself)
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        i would but the last time i tried extracting a picofuse off a dead mobo i burned it up... maybe i need to turn down the heat.
        the hdd is on a daughterboard on my model... and the fan i is not always 5v.... so idk where to go. perhaps the alternate power for the dbay port (the good usb) would work.
        sigpic
        • Scenic
          o.O
          • Sep 2007
          • 2642
          i meant one of these.. not the surface mount type
          http://i12.ebayimg.com/04/i/000/fb/6e/a04e_1.JPG
          • yyonline
            • Jul 2009
            • 692
            Don't ask me how, or why, b/c it makes no sense... but I once managed to fix this problem in a D800 by removing all the USB ports/hubs/controllers from Device Manger, rebooting, and letting it redetect them. It's worth a shot.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              tried it and it didn't work.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                i think i have it.
                the dbay extension, used to gove ADDITIONAL poer to the lef usb port, is on the SAME plane as the right usb port's 5v pin.
                thefrore, the plane has more then the usual load
                i think i will run a jumper wire from the dbay 5v plane to the back usb 5v plane. i was able to do it on my old board without any major issues.
                sound like plan?
                sigpic
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  wow. that post hass too many typo's. what i meant to say:
                  i think i have it.
                  the dbay extension, used to gove ADDITIONAL power to the left usb port, is on the SAME plane as the right usb port's 5v pin.
                  therefore, the plane has more then the usual amount of juice.
                  i think i will run a jumper wire from the dbay 5v plane to the back usb 5v plane. i was able to do it on my old board without any major issues (physically, not able to power test it).
                  sound like a safe plan?
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    anybody? i don't want to do it unless i have some input from the experts around here...
                    sigpic
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Well, what would you want to hear? I'd go ahead and do it, BUT cut the old 5v trace to the USB port just to be sure.
                      A working TV? How boring!
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        based on what i was seeing, i think all of the traces go to the same place.
                        trying it soon.
                        sigpic
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Not necessarily. USB ports have overcurrent protection so at the very least each one will have a current sensing shunt.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            then why are 2 sources meant to be used to exeed usb power put on the same trace? i assume that means i can use just a jumper wire?
                            sigpic
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              I can't understand you, rephrase please.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                abothe the right port (working) there is an additional 5v boost connection for dell dvd drives. it and the port are on the same 5v trace. since the purpose of the 5v is to give additional power to the usb port, that means the trace can power more than 1 usb port.
                                sigpic
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  The shunt resistors may be there without you seeing them.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    uhh... the pins are literally on the exact same giant plane. as in a plane 1cm wide has 2 holes in the area, one for each pin. and it ain't ground either, which is similar but bigger (for the usb shell).
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      all considered, I would like a final look over from an expert since my new freebie laptop was a bust and this is all i have to play with... if it is likely safe, i will go ahead and do it. if not, then i will not.
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        bump
                                        sigpic
