macbook pro a1989 T2 activition error
  • ansen43
    • May 2013
    • 8
    • ireland
    Hi, I have this macbook with MDM. so i removed T2 and change s/n, and put it back. now it stuck at "there was an error activating your device. please try again" can someone please help. thanks
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    MDM removal activation locked error requires a serial that is recognized by Apples Servers. You can't just randomly remove a serial and just hope it works.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Also to add, if you do a proper serial and it is still giving errors, chances are it is actually activation locked to that serial, the T2 chip requires the serial to match the T2 chip with apple servers. If it was a true MDM lock the T2 chip never gets activated on the server. But if it is a normal user the T2 chip is locked assigned to the server with the serial off the rom chip. So it's a double edged sword. MDM locks need to be verified before you attempt to remove them. You can determine if the MDM is locked or is an activation lock. Paper weight for that board basically.
      sigpic
      • volinakis
        • Jan 2021
        • 2744
        • N/A
        you can skip MDM, take a look on github ...
        • ansen43
          • May 2013
          • 8
          • ireland
          OK, so here is the thing now. I have 2 A1989 came in, one with MDM. one with activation lock. when i post last time, i was working on the MDM one. i try SKIPMDM.COM and somehow it didn't work. so i remove the small chip (not the acture T2), and change s/n( i change to some other model's s/n, not the same model from another a1989. it have activation error. so i change again with a very old s/n, still no luck. so i post request here. and i was a bit upset, so i change the s/n back to the original one. this time the MDM dispeared. everything working find now.
          yesterday, i start working on the second a1989 with activation lock.
          1: i change the s/n same as the one with mdm, it didn't work, showing activation error again. i was suprised. because that s/n is find, without activation lock. it was just mdm, and removed.
          2: so i copy whole bin file from the mdm machine, same. activation error.
          3: i write the original bin file with activation lock back, but change another none a1989 s/n, same, activation error
          4: write whole mdm machine bin file but change s/n to none a1989 model. same, activation error.
          so i'm stucked now. i was thinking using checkm8 to do that. do you guys have any suggestion?
          thanks.
          • curiositymaster
            • Apr 2021
            • 45
            • Nigeria
            thanks.
            When you change an activatiion-locked T2 Mac Serial, the Mac won't be able to pass the activation check. This is why you will always get activation error. You need to put back the original file (with sn) and you activation process will proceed to the next step (where it asks for Icloud details).
            Also, you cannot remove activation lock by swapping SN (with clean SN). It could only be removed from the Apple server or if you can manage to swap T2 chip (from an unlocked board).
            • curiositymaster
              • Apr 2021
              • 45
              • Nigeria
              Hello mate, have you tried MDM removal on the latest BridgeOS? It seems they now lock the system to the new serial (if it's already tied to an iCloud account).
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • ErinV
                MacBook Pro A1989 820-00850-A not powering on
                by ErinV
                Hey everyone!
                I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                The diode voltages around all 4 CD3215's seem fine.
                For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                09-30-2024, 10:21 PM
              • Madoy104
                Macbook Pro A1989 - No image, working fine with external monitor
                by Madoy104
                I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                08-15-2024, 10:01 AM
              • dbuergi
                Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
                by dbuergi
                this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
                Is there anything i can do?
                11-19-2024, 09:27 AM
              • PITERPENY
                Macbook A1989, 820-00850, won't boot. 20V, 0A.
                by PITERPENY
                Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                Here are some measurements, maybe someone can tell what the problem is.
                The initial problem was a burnt out induction coil L8504 (replaced).
                When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                here are some measurementsmotherboard...
                01-16-2024, 02:19 PM
