green led blinks no image Razer Blade 15” Advanced (2021) | RZ09-0409x
  • evgenyjp
    • Dec 2020
    • 8
    • japan
    Hi !
    I got laptop that won't show image on screen, but looks it working.
    Have all powers.Bootable usb flash memory is blinking and looks booting. Capslock is responding.Fans is spinnig.
    But no image on screen and green led is always blinking.
    Seems to me this is "Modern Stanby" mode advertised on Razors website and laptop is stuck in this mode.
    I did remove battery and CMOS. no luck.
    I reflash bios from Razors page but still no changes, still blinking and no image.
    Is there any else I could check, any ideas?
    Thanks!
  • chickenhawk88
    • May 2024
    • 86
    • US
    I'm still working on my Razer blade 15 as I should have just left it alone 😡. The original fault was powers on , keyboard rgb on, but no display on lcd or hdmi. I found corrosion on memory module had leaked onto socket. I removed the bad memory and left the other good memory in other socket. Cleaned/removed corrosion from socket. Everything worked great minus bad memory socket.
    So I tried to find out what was wrong with the other socket. I replaced a dual mosfet by memory socket, a 330uf cap, and buck chip on back. I hooked everything and heard loud pop and smelled smoke. Now I'm in deep hole trying figure it out.
    • popzeggey
      • Aug 2019
      • 15
      • ghana
      Originally posted by evgenyjp
      Hi !
      Thanks!
      I have the exact same issue
      • Razor0601
        Razer Blade 15 advanced Late 2019
        by Razor0601
        Hello, I bought a Razer blade 15 advanced with I7-9750h and RTX 2080 without Display. Seller said it works with external display. It arrived and I connected it to my Samsung TV. It gave me an external Pic with windows 11 start screen. But I had no Windows account so I removed the SSD and installed it in my other laptop to install windows 10. put it back in the Razer but from this time I never got an external pic. Can anybody help me to get back an external pic?
        BTW: I‘m sure the LCD-cable is bricked and not the LCD itself.
        09-15-2023, 04:57 AM
      • sikocan
        Razer Blade 15 Gaming Advanced RZ09-0421 Laptop - No Display, External Screen Only
        by sikocan
        Hello Colleagues,
        I'm dealing with a perplexing issue on a client's laptop and would appreciate your insights. The user experienced a sudden screen blackout during regular use (not gaming), although the laptop continued to operate normally otherwise, with music playing and indicator lights active. An external display connected via HDMI works fine, indicating the display itself is functional. The device manager shows the Intel XE GPU as disabled, with Windows reporting a related error, while the NVIDIA RTX GPU operates without issues, even supporting gaming.
        Upon inspection,...
        11-28-2023, 12:14 AM
      • shybear
        GPU VBIOS for Razer Blade 15 Advanced (RZ209-033)
        by shybear
        hi,
        when I power ON this laptop it give me this red warning message:
        "the detected discrete gpu VBIOS is not meant for this system, press Enter to continue"
        Machine start and works properly. I was also able to update machine BIOS to last version 1.06.
        I attach here a copy of the orginal VBIOS stored on GPU flash memory chip.
        Thanks so much for help....
        04-01-2025, 04:03 AM
      • shybear
        Razer Blade 15 Advanced (RZ209-033) graphic card issue
        by shybear
        hi,
        this laptop works but temperature rise too much. I dismounted mb and cleaned well. There was a lot of dust inside.
        I think that there is a graphic chipset issue because when I power the machine I get this error:
        "the detected discrete gpu VBIOS is not meant for this system"
        This make me think that maybe the gpu VBIOS has to be re programmed.
        BTW someone already worked on this mainboard. Near graphic board there is Winbond flash memory that I think its stored the VBIOS.
        I attach some pictures and one of message error I get when I power on the ...
        03-26-2025, 02:36 PM
      • Themi
        Razer blade advanced 2020
        by Themi
        Hi all
        Repairing a 2020 Razer blade advanced, 10th gen intel + 2080 max q. Originally had a destroyed charging port (soldered to the board type) which I've replaced and then found out it was missing the 20v rail which loops around the board.
        Found a 3r030 mosfet which was shorted gate to drain so replaced that and now have 20v rail, 3.3v, 5v but still unable to power on successfully.
        When powering on there's no activity at all. The PCH gets hot but nothing else. At this point I gave up last night to attempt again today with fresh eyes.
        10-16-2022, 07:50 AM
