Razer Blade 15 advanced Late 2019
  • Razor0601
    • May 2021
    • 34
    Hello, I bought a Razer blade 15 advanced with I7-9750h and RTX 2080 without Display. Seller said it works with external display. It arrived and I connected it to my Samsung TV. It gave me an external Pic with windows 11 start screen. But I had no Windows account so I removed the SSD and installed it in my other laptop to install windows 10. put it back in the Razer but from this time I never got an external pic. Can anybody help me to get back an external pic?
    BTW: I‘m sure the LCD-cable is bricked and not the LCD itself.
  • mon2
    • 14539
    Re: Razer Blade 15 advanced Late 2019
    You are probably missing the machine specific device drivers to drive the external screen hardware. Locate the device driver packages for the target machine and be sure they are windows 10 friendly before proceeding. Often, they will be.
    • Razor0601
      • May 2021
      • 34
      Maybe the ssd from my Clevo P775TM with I9-9900k and RTX 2080 could work?
      • Razor0601
        • May 2021
        • 34
        Also doesn’t work. I bought a complete Display assembly from eBay. 144hz with same 40-pin connector. Hopefully it will work
        • Razor0601
          • May 2021
          • 34
          So I got the whole display assembly. But also doesn’t work. But what I now realized is that the green front LED is Blinking/flashing slow. Is that the sign that it is connected to an external Display?
          • Razor0601
            • May 2021
            • 34
            Has someone an idea?
            • Razor0601
              • May 2021
              • 34
              So I did another Bios reset. And now it’s working.
              • sikocan
                Razer Blade 15 Gaming Advanced RZ09-0421 Laptop - No Display, External Screen Only
                by sikocan
                Hello Colleagues,
                I'm dealing with a perplexing issue on a client's laptop and would appreciate your insights. The user experienced a sudden screen blackout during regular use (not gaming), although the laptop continued to operate normally otherwise, with music playing and indicator lights active. An external display connected via HDMI works fine, indicating the display itself is functional. The device manager shows the Intel XE GPU as disabled, with Windows reporting a related error, while the NVIDIA RTX GPU operates without issues, even supporting gaming.
                Upon inspection,...
                11-28-2023, 12:14 AM
              • plyanthony
                Razer Blade 15 no external display with attached screen disconnected from motherboard
                by plyanthony
                Computer in question : Razer Blade 15 2020 Base Model
                Model# RZ09-03286E22
                BIOS CHIP: WINBOND W25Q128BV
                What I'm trying to accomplish:
                I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                W/Stock BIOS - 1.06:
                Disconnect the...
                02-01-2023, 09:35 PM
              • shybear
                GPU VBIOS for Razer Blade 15 Advanced (RZ209-033)
                by shybear
                hi,
                when I power ON this laptop it give me this red warning message:
                "the detected discrete gpu VBIOS is not meant for this system, press Enter to continue"
                Machine start and works properly. I was also able to update machine BIOS to last version 1.06.
                I attach here a copy of the orginal VBIOS stored on GPU flash memory chip.
                Thanks so much for help....
                04-01-2025, 04:03 AM
              • shybear
                Razer Blade 15 Advanced (RZ209-033) graphic card issue
                by shybear
                hi,
                this laptop works but temperature rise too much. I dismounted mb and cleaned well. There was a lot of dust inside.
                I think that there is a graphic chipset issue because when I power the machine I get this error:
                "the detected discrete gpu VBIOS is not meant for this system"
                This make me think that maybe the gpu VBIOS has to be re programmed.
                BTW someone already worked on this mainboard. Near graphic board there is Winbond flash memory that I think its stored the VBIOS.
                I attach some pictures and one of message error I get when I power on the ...
                03-26-2025, 02:36 PM
              • Themi
                Razer blade advanced 2020
                by Themi
                Hi all
                Repairing a 2020 Razer blade advanced, 10th gen intel + 2080 max q. Originally had a destroyed charging port (soldered to the board type) which I've replaced and then found out it was missing the 20v rail which loops around the board.
                Found a 3r030 mosfet which was shorted gate to drain so replaced that and now have 20v rail, 3.3v, 5v but still unable to power on successfully.
                When powering on there's no activity at all. The PCH gets hot but nothing else. At this point I gave up last night to attempt again today with fresh eyes.
                10-16-2022, 07:50 AM
