Razer blade advanced 2020
  • Themi
    • May 2020
    • 79
    • Scotland
    Hi all
    Repairing a 2020 Razer blade advanced, 10th gen intel + 2080 max q. Originally had a destroyed charging port (soldered to the board type) which I've replaced and then found out it was missing the 20v rail which loops around the board.
    Found a 3r030 mosfet which was shorted gate to drain so replaced that and now have 20v rail, 3.3v, 5v but still unable to power on successfully.
    When powering on there's no activity at all. The PCH gets hot but nothing else. At this point I gave up last night to attempt again today with fresh eyes.
    I am wondering if anyone has any ideas of what might be worth inspecting next. I feel like the PCH isn't firing up the cpu for some reason but I haven't properly checked for a 1v rail yet. I was also thinking of putting the board under the thermal camera just to check for any other areas of activity when attempting to power on.
    If anyone wants images for voltages measured just ask and I'll post them here.
  • mon2
    • 14665
    Re: Razer blade advanced 2020
    Check the resistance to ground of the coils near the CPU / PCH. From the assorted posts and readings, if the PCH is getting hot then it is game over as the CPU (with the PCH) needs to be replaced. Unless you have a proper SMD reflow station, the replacement of a massive part like this is difficult. We have such a tool but openly little free time to proceed with this learning task. Hope to do so before the end of the year. The tool has worked very well to remove TQFP / BGA devices. It is from Seamark (China) and is able to support down to 0.5*0.5mm devices with an automatic placement / removal process.
    Large BGA devices will demand a proper underside heater.
    • Themi
      • May 2020
      • 79
      • Scotland
      Thanks for the info. I do fear this might be the case as usually once the 3.3, 5 and 20v rails are active things are looking up. This is the first Razer I've worked on where these rails have been active yet the machine won't power on. Re the resistance measurements between coils near the cpu/pch and ground I have previously done the same measurements on other Razer blades and the resistance has been very low (almost seeming like a fault) yet those laptops have worked fine. I am guessing possibly because they are very low impedance lines?
      Nevertheless I'm out at the moment but once I'm back I'll make these checks and see what the readings are.
      • Themi
        • May 2020
        • 79
        • Scotland
        One side note, bit of a long shot. Could a corrupt bios be causing a failure to power on? Behaviour when attempting power on is nothing happens at all. No fan spin when plugged in, no activity when power button pressed. Holding the power button for an extended period causes the charging led to flash white, once.
        • mon2
          • 14665
          Yes, low voltage rails like CPU / GPU / PCH will have low resistance readings to ground. We had a macbook (a1398) that was with a 1 ohm resistance to ground, yet worked fine.
          Yes, a corrupt bios (like politicians) can impact the operation. There is the main bios and perhaps the local bios for the KBC controller (not my area of experience - KBC virgin you could say). Wait on others to comment. You should always backup your original bios before erasing your original and confirm with 110% confidence on the Vcc voltage of your BIOS. Not all bioses are 3v3 style so you must be sure your programmer can handle the assorted variety that may be on your board (ie. 1v8 style).
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            if u google for razer blade flash after 10 second power botton press it's full of dead razer notebook..
            about your notebook, the green led on the front turn green?
            3,3 and 5 volt on new notebook models shoud comes on only after power botton is pressed (not sure). check if u get other voltage with 3,3 and 5 volt. check bios volts.
            3r030 mosfet u have replaced was inline with what power rail? cpu gpu pch... anso check what volts it has in and out... probably if it get 20volt it has destroyed the entire line...
            wait for update.
            hot pch mean terrible hot or just a bit warm ?
            • Themi
              • May 2020
              • 79
              • Scotland
              Lol politicians!. I may try the bios at some point this week because I cannot find anything else that is wrong. It appears all the power rails are operational but the machine refuses to start and appears dead. I will backup before hand and find an alternative bios to write. Reader wise I have a CH341A. I'll have to check if this supports the bios ICs I have.
              Is the IC to the left of the battery is the bios? I see two others around the PCH.
              • Themi
                • May 2020
                • 79
                • Scotland
                wait for update.
                no green light when attempting to power on
                only the single white light flash when holding the power button for around 10-15s
                3.3 and 5 do come up after the power is pressed. I'll check the bios volts but I'm not actually sure which is the main board bios. I've posted an image above of 3 that are likely candidates.
                the 3r030 is inline with a 20v circuit that loops around the board, various components pull from it though and convert to lower voltages. I do hope it hasn't destroyed everything but can't rule it out tbh
                hot PCH as in terribly hot. I'll measure the heat off it tonight but it's going to be well into 70c however on this model it's heatsinked so not sure if it naturally runs hotter in this model
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  bios must be a 25 something 128 or 64, depending on bios size.. 16mb or 8mb...
                  • shellybelly
                    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                    by shellybelly
                    Back Story
                    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                    08-27-2023, 10:40 PM
                  • Razor0601
                    Razer Blade 15 advanced Late 2019
                    by Razor0601
                    Hello, I bought a Razer blade 15 advanced with I7-9750h and RTX 2080 without Display. Seller said it works with external display. It arrived and I connected it to my Samsung TV. It gave me an external Pic with windows 11 start screen. But I had no Windows account so I removed the SSD and installed it in my other laptop to install windows 10. put it back in the Razer but from this time I never got an external pic. Can anybody help me to get back an external pic?
                    BTW: I‘m sure the LCD-cable is bricked and not the LCD itself.
                    09-15-2023, 04:57 AM
                  • maybepanic
                    Razer Blade Stealth 2020 13" RZ09-03102 EC firmware
                    by maybepanic
                    Hey,
                    I've got an Razerblade that didn't show any signs of life. When connecting to an USB power meter it showed roughly a 100mA draw at 20V. Opened it up and the EC chip was showing 65°C, nothing else getting warm. I ordered a replacement IT8320VG-256 and replaced it in the hopes it'd write the firmware on its own. Didn't work. I've got a Vertyanov Programmer so I was hoping to find the firmware in a BIOS dump and flash it via the keyboard connector. Got a bios dump from a discord channel but as far as I can tell there is no EC firmware to be found inside. I searched for "ITE",...
                    10-24-2025, 04:01 AM
                  • satabell
                    [REQUEST] Razer Blade 15 [2020] RZ09-0328x Overclock menu Unlock
                    by satabell
                    Razer Blade 15” (2020) - Base Model | RZ09-0328x
                    CPU - i7-10750H
                    GPU - RTX 2060
                    https://mysupport.razer.com/app/answers/...8x-support
                    BIOS DUMP:
                    I tried Neoprogrammer v2.2.0.10 and AsProgrammer V2.1.0.13, using the CH3141 3.3v mod.
                    All i'm getting a black screen ( keyboard lights up)
                    Thank You,
                    12-16-2022, 07:23 PM
