Macbook A1706 no power
  • Lakai
    • Jun 2015
    • 6
    • France
    Hi all!
    Got this touchbar 2016 macbook, topcase and battery replaced by apple for the ancient owner, suddenly died.
    No corrosion or liquid trace, perfect condition.
    -20v negociated
    -no PPBUS_G3H
    Removed f7000, short on pin2, then I have PPBUS_G3H 13V.
    Injected 0.9v 2A on pin2 of F7000, power removed, the only component that gets little warm is U7960.
    Removed L7960, current injection on pin2, amperage rising to 2.4A then stabilizes...
    Any clues for this one?
  • techetronic
    • May 2017
    • 12
    • qatar
    Re: Macbook A1706 no power
    mb part number?
    • Lakai
      • Jun 2015
      • 6
      • France
      820-00239 sir
      • Lakai
        • Jun 2015
        • 6
        • France
        When L7960 removed:
        PPBUS_G3H 13.1 V
        PP3V3_G3H 3.3 V
        PP3V0_G3H 3.0 V
        No cpu rails, 0v6 rail or 1v rail
        PP1V8_SUS 0.015v
        PP5V_S4 5.14 V
        PP3V3_S5 3.35 v
        PP3V3_S5_T139 3.3 V
        • Lakai
          • Jun 2015
          • 6
          • France
          PPVCC_S0_CPU 7 ohm
          PPVCCGT_S0_CPU 5 ohms
          PPVCCSA_S0_CPU 3 ohms
          PPBUS_G3H to PPVCC_S0_CPU=477 ohms
          PPVCCIO_S0_CPU to ground=2 ohms
          Forgot to mention, board is 820-00239...
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            I have the same problem. But i don't have 1.8 volts
            • mon2
              • 14677
              If a voltage is missing, remove all power and check the resistance to ground of the missing voltage rail. Next check if the rail is being enabled by checking the voltage to ground of the enable pin.
              • PITERPENY
                • Jul 2023
                • 461
                • Ukraine
                power supply 20v. 0.00A
                PPVIN_G3H_P3V3G3H =19.66V
                but on L7030 = 0.200V but there should be 13V. Tell me what could be the problem ?
                • Danielreinaa
                  HELP need password bios Macbook A1706
                  by Danielreinaa
                  Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                  Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                  Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                  gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                  Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                  09-07-2024, 03:47 PM
                • capon5153
                  Macbook A1706 works perfectly but no data on USB C
                  by capon5153
                  hello,
                  so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                  i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                  06-22-2025, 09:42 AM
                • B2L_Repairs
                  Macbook A1706 touchpad and keyboard not working. Please help
                  by B2L_Repairs
                  Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                  10-09-2023, 04:56 AM
                • obelix24
                  A1706 - Macbook pro - one USB-C port only 20V 0A
                  by obelix24
                  I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                  I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                  There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                  There were some broken pads under CD3215 but i've recreated them.
                  What should be...
                  05-22-2024, 08:04 AM
                • envym
                  by envym
                  Hi everyone!
                  06-27-2025, 08:54 AM
