Acer 6930g-no power
  • manol278
    • Nov 2017
    • 41
    • greece
    Acer 6930g-no power
    Acer 6930 gr. I turn on the power. The lights come on for 1-2 seconds and the laptop shuts down. When the hard drive is disconnected, the laptop starts normally!!! I have done bios programming, NorthBridge refresh. Nothing changed. Maybe the hdd controller is at fault? Who is the controller? Motherboard da0zk2mb6e0 rev e
  • rookieme
    • Oct 2014
    • 396
    • Greece
    Re: Acer 6930g-no power
    Have you checked with a second hdd too?
    If not the hdd could have a short and it's shorting the power rails.
    Also the hdd is connecting to the southbridge so do a visual check there and at hdd motherboard connector.
    • manol278
      • Nov 2017
      • 41
      • greece
      I tried another hard drive,i checked the motherboard hdd slot.No result.
      Where are the hard drives usually connected to the motherboard? To the southbridge or on some controller? Τhere is a short circuit somewhere...
      • rookieme
        • Oct 2014
        • 396
        • Greece
        Your motherboard has 4 data lines from hdd to southbridge.
        Also takes the 3,3V and the 5V.
        You could measure if there is voltage drop at the two power lines when you have the hdd connected.
        You could also try if you don't use the dvd drive to remove it and place a hdd caddy there to put the hdd there.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          Tankless hot water heater controller board not powering up when power is applied
          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
          However I would like to know if I could figure what happened to this controller board if possible
          Tomorrow I will take some better pictures of both side of both boards
          The...
          12-09-2022, 09:14 PM
        • usbdevice
          Acer X223HQ (Version Bbd) on/off-power-cycling
          by usbdevice
          Hi all
          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
          https://www.badcaps.net/forum/showthread.php?t=50657
          https://www.badcaps.net/forum/showthread.php?t=40512
          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
          It's my dad's old monitor. He...
          08-05-2022, 02:21 AM
        • Bonaventure Vigil
          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
          by Bonaventure Vigil
          Dear All,
          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
          12-12-2024, 10:22 AM
