Does a vccio short mean bad cpu?
  • motanya
    • Nov 2021
    • 158
    • Kenya
    This laptop, hp 1030 g2 OLDMAN-6050A2848001-MB-A01 came in with a burnt AKVH ic, removing it, the 19v short goes away but there is very low resistance on the coil after the chip(1.6ohms), replacing it, the laptop turns on but no display, cpu is cold and the chip overheats, does it mean the cpu is dead or something else is dead.(From most hp schematics, I have seen them use the chip for vccio, not sure though, I stand corrected)
    No schematics or boardview for this board
  • MuertoGB
    • Sep 2021
    • 92
    Re: Does a vccio short mean bad cpu?
    If you have a short on VCCIO you should start by removing the inductor between the VCCIO generator and CPU, then determining which side the short is coming from.
    However, in most cases, I've found shorted VCCIO is coming from the CPU; which means board, or CPU replacement + ME clean (if the PCH is embedded).
    If the short is coming from the CPU you could inject 0.9v, there's a very small chance it could be a capacitor.
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • aaronkatrini
      Help me find the short circuit on this WORKING Nvidia GTX1650
      by aaronkatrini
      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
      04-18-2024, 03:15 PM
    • Geeker007
      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
      by Geeker007
      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
      I am new to electronics repair, so my queries could be naive but I am ready to learn.
      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
      01-28-2025, 03:31 PM
