UK Supplier Of Laptop Components - HDMI Port
  • RetroComputingGrotto
    • Aug 2023
    • 88
    • United Kingdom
    I've got a HP 255 G7 with a broken/worn out HDMI port that I need to replace.
    For whatever reason, the company I work for does not allow us to buy parts from eBay so I'm looking for a UK based company that supplies things like HDMI ports for laptops so if anyone uses one then can you please let me know?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: UK Supplier Of Laptop Components - HDMI Port
    Maybey digikey?
    • reformatt
      • Feb 2020
      • 1412
      I don't know any supplier (Digikey, Element 14 etc) that lists ports by laptop model. You need to know the original part number to get anywhere with that usually. If you have the schematic, then use any part number listed to search from those vendors.
      I usually get these things off Aliexpress, or a dead donor board.
        • Aug 2023
        • 88
        • United Kingdom
        Originally posted by Stevedb
        Maybey digikey?
        Thanks! I'll take a look
        I've been looking in service manuals for any kind of part number, no idea why I didnt think about looking on a schematic so thanks for that
        We can't use Aliexpress either unfortunately - I'm a bit apprehensive about using ones from a donor board in case I damage/melt the plastic part of the HDMI port.
        • reformatt
          • Feb 2020
          • 1412
          In the PC space, motherboards are considered a whole service part, like a screen or keyboard. You get nowhere asking for something like a USB or HDMI port, and you get told you need to replace the whole board. It keeps the servicing side of it cheap as you can just get monkeys to swap things out. We used to call people like that "board jockeys" when I worked at a TV station years ago. This was considered an insult to those techs that avoided component level repair. Now it is the norm, not the exception, but I digress.
          So harvesting off donors is absolutely essential. Especially if you just need a one off (or you can't use other sources like Aliexpress etc to source them). It does take practice (this is why junk boards are great) and what nozzle/temps/air flow work with your hot air station. In the case of HDMI ports (and USB-C ports with concealed pins), you heat from the reverse side of the connector. If you have the board inverted on the bench when you get to reflow temp, a slight wiggle/tap will make the connector fall out. Normally the plastic will be untouched.
          Low melt solder like Chipquik makes this far easier too on some connectors where the pins are exposed. That stuff is brilliant.
            • Aug 2023
            • 88
            • United Kingdom
            20+ years ago I qualified as an Electronics Servicing Engineer where I was taught to fix motherboards down to component level - (until now) all my subsequent jobs taught me not to repair a motherboard but to replace it so for all these years I've barely used my electronic repair skills so having to re-learn lots!
            It's a shame it's company policy to not use Aliexpress or eBay as the parts I tend to need are pretty much all on there (including the HP HDMI port I need)!
            We have a couple of boxes of 'Spares and Repairs' laptops for me to practice on so thanks for the tips regarding using a hot air rework station to remove said components, I'm going to spend some time today just randomly taking of ports to gain some experience (and slowly build up some spare parts)!
            • RossMoodley1967
              LG LCD TV HDMI PORT FAULTY
              by RossMoodley1967
              LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
              02-28-2024, 08:38 AM
            • Gjackson
              Original PS4 BLOD after replacing HDMI port.
              by Gjackson
              Hi, ill try to keep this short. I got my hands on a PS4 with a mangled HDMI port and assumed that it would be an easy fix. before the replacement it booted up fine (white light) however after replacing the port it booted up fine for 2 times and then after plugging in an HDMI cable and turning on the console to check whether it had video out it never booted again, even after unplugging the cable. now it gets stuck on the blue flashing light and after 25-40 seconds it pops out the disk (if one is inserted) and shuts itself off. Upon investigating i found that the capacitors near the HDMI port are...
              10-22-2021, 02:14 PM
            • survivalbloke
              PS5 - no video but hdmi port looks ok
              by survivalbloke
              I'm a little green when it comes to consoles. I've done a fair amount of hdmi port replacement but not really any diagnostics. I've got a PS5 here which powers up but has no video output. I've also tried to boot to safe mode, also with no video. The hdmi port does not look damaged.
              Where do I go from here? Thanks!
              **UPDATE** I take that back. The external part of the port looks fine, but look at the pins to the mobo. Those pads are ripped off. How does this happen when the feet of the port are still sturdily soldered to the board?
              **UPDATE 2** The pads were...
              04-12-2023, 03:29 PM
            • SuperAman
              PS5 HDMI port diode reading?
              by SuperAman
              I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
              02-03-2024, 10:16 PM
            • amuse619
              Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
              by amuse619
              Hello!
              Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
              Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
              08-14-2024, 01:22 PM
