UK Supplier Of Laptop Components - HDMI Port
  • RetroComputingGrotto
    • Aug 2023
    • 92
    I've got a HP 255 G7 with a broken/worn out HDMI port that I need to replace.
    For whatever reason, the company I work for does not allow us to buy parts from eBay so I'm looking for a UK based company that supplies things like HDMI ports for laptops so if anyone uses one then can you please let me know?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: UK Supplier Of Laptop Components - HDMI Port
    Maybey digikey?
    • reformatt
      • Feb 2020
      • 1446
      I don't know any supplier (Digikey, Element 14 etc) that lists ports by laptop model. You need to know the original part number to get anywhere with that usually. If you have the schematic, then use any part number listed to search from those vendors.
      I usually get these things off Aliexpress, or a dead donor board.
        • Aug 2023
        • 92
        Originally posted by Stevedb
        Maybey digikey?
        Thanks! I'll take a look
        I've been looking in service manuals for any kind of part number, no idea why I didnt think about looking on a schematic so thanks for that
        We can't use Aliexpress either unfortunately - I'm a bit apprehensive about using ones from a donor board in case I damage/melt the plastic part of the HDMI port.
        • reformatt
          • Feb 2020
          • 1446
          In the PC space, motherboards are considered a whole service part, like a screen or keyboard. You get nowhere asking for something like a USB or HDMI port, and you get told you need to replace the whole board. It keeps the servicing side of it cheap as you can just get monkeys to swap things out. We used to call people like that "board jockeys" when I worked at a TV station years ago. This was considered an insult to those techs that avoided component level repair. Now it is the norm, not the exception, but I digress.
          So harvesting off donors is absolutely essential. Especially if you just need a one off (or you can't use other sources like Aliexpress etc to source them). It does take practice (this is why junk boards are great) and what nozzle/temps/air flow work with your hot air station. In the case of HDMI ports (and USB-C ports with concealed pins), you heat from the reverse side of the connector. If you have the board inverted on the bench when you get to reflow temp, a slight wiggle/tap will make the connector fall out. Normally the plastic will be untouched.
          Low melt solder like Chipquik makes this far easier too on some connectors where the pins are exposed. That stuff is brilliant.
            • Aug 2023
            • 92
            20+ years ago I qualified as an Electronics Servicing Engineer where I was taught to fix motherboards down to component level - (until now) all my subsequent jobs taught me not to repair a motherboard but to replace it so for all these years I've barely used my electronic repair skills so having to re-learn lots!
            It's a shame it's company policy to not use Aliexpress or eBay as the parts I tend to need are pretty much all on there (including the HP HDMI port I need)!
            We have a couple of boxes of 'Spares and Repairs' laptops for me to practice on so thanks for the tips regarding using a hot air rework station to remove said components, I'm going to spend some time today just randomly taking of ports to gain some experience (and slowly build up some spare parts)!
            • amuse619
              Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
              by amuse619
              Hello!
              Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
              Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
              08-14-2024, 01:22 PM
            • User2025
              Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
              by User2025
              I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
              It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
              I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
              04-29-2025, 04:13 PM
            • RossMoodley1967
              LG LCD TV HDMI PORT FAULTY
              by RossMoodley1967
              LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
              02-28-2024, 08:38 AM
            • marce002
              Laptop HDMI port dead after storm
              by marce002
              Hello
              I would like someone who can give me some hints about this issue. i was working on the laptop msi gamer GE758sf under stomy night, and when a lighstrike hit my neigbourhouse , hdmi output was cut all of a sudden.. laptop works fine but need to try to repair any cap or what you could tell me can get damaged in this circunstances...i have skills to do micro soldering the problem is that i do not have any schematics or boardview to start to measure the board...
              note that the samsung led momitor is ok and working fine with another laptop same cable.
              09-08-2022, 06:44 PM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
