MacBook Air A1466
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    MacBook Air A1466
    I have one MacBook Air (mid 2012) A1466 with i7 and it's working but after some time it turns off and then reboots and sometime I'm able to log on to macos and then it just turns off and after few seconds it tries to turn on.
    I've checked the board and there was almost no thermal paste on CPU so I've put their fresh one. I've also checked the board and there is no visible corrosion / water damage (but I can be that it was cleaned before)
    when I let it off for some longer time I'm able to turn it on and work on it normally but then this happened again.
    I don't understand what's happening. I've installed fresh macOS and updated it.
  • reformatt
    • Feb 2020
    • 1400
    Re: MacBook Air A1466
    Sometimes this can be a bad ISL, crap under the SMC, CPU needs a reball, or more often its a corroded pad under a 0201 component somewhere on the board.
    If its been through an ultrasonic, tell tale signs should still be there by looking for dull end caps on passive components. Any that are dull or black, are suspect. You can hit them with hot air and flux, nudge them and see if the spring back onto the pad. If not, you take of the resistor/cap, and see the condition of the pad itself. Often they are eaten away and need jumpering etc.
    • RethoricalCheese
      • Mar 2013
      • 1517
      • Estonia
      Could just be a bad power button acting up.
      • obelix24
        • Jun 2023
        • 291
        • Slovakia
        I've tried new battery and run geekbench test for CPU it finished OK but when i run it for GPU it was running and then it turns off (but GPU i've started right after CPU was finished so maybe it's connected)
        i've let it for while and checked later and i was again able to login to OS and work but after some time it again turns off (i've checked battery health and it's good (99%) according to Stats app.
        I don't think it's power button as it's working correctly when i try to turn it on or off.
        • RethoricalCheese
          • Mar 2013
          • 1517
          • Estonia
          Doesn't really matter, it's quick enough to just test it by disconnecting keyboard after turning on. Then you know for sure.
          Seen it before, power button works but has a mind of it's own aswell and makes the laptop turn off at random times.
          • obelix24
            • Jun 2023
            • 291
            • Slovakia
            so turn on and disconnect and operate with external keyboard ? will it not hurt anything disconnecting keyboard while battery is connected ?
            • RethoricalCheese
              • Mar 2013
              • 1517
              • Estonia
              Yes. No issues disconnecting.
              • marce002
                Macbook A1465 works fine Linux but turns off in MacOS
                by marce002
                Hello
                I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
                Formating and installing does not work because it also turns off.....
                But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
                So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with...
                02-02-2022, 05:43 PM
              • redbaron1007
                Macbook AIr a1466 Trackpad jittery/nonresponsive in macos, but not in recovery mode.
                by redbaron1007
                I've got a MacBook Air A1466 that had liquid damage that I got working entirely except for the trackpad. The track pad is jittery or outright unresponsive when it is in macos, but works perfectly fine in recovery mode. The keyboard works and there are no issues with any of the keys not pressing. I have also replaced the track pad with 2 known good track pads and still am having issues with it.
                I can't find anything wrong on the board with any of the IC's that would be in circuit with the track pad and am assuming it's some sort of os issue, but I don't know how macOS actually works...
                04-28-2023, 10:20 AM
              • sureshbobby
                Macbook air A1466 Shutting Down while installing Macos
                by sureshbobby
                Hi friends
                i have Macbook air a1466
                unable to Install macos while installing it shutdown after some time
                any solution
                please help
                07-02-2022, 10:20 PM
              • psdavid65
                Macbook Air A1466 820-3437-B Booting Problem
                by psdavid65
                I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                06-20-2024, 12:27 AM
              • 24gsm
                MacBook Pro A1708 install macos fail
                by 24gsm
                hi to all
                i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                after enter to recovery and format hdd 1to .
                after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                can help please
                Serial Number: FVFXP0U0HV2J
                Config Code: HV2J
                Find My Mac: OFF
                04-16-2025, 03:57 AM
