MacBook Pro A2338 keeps restarting when attempting to install macOS
  • Simplebeans
    • Sep 2021
    • 135
    I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
    After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before the freeze and restart occurs.
    I also ran Apple Diagnostics on the machine and this reported no faults.
    I am starting to think it could possibly be a SSD issue however there is no abnormal heat detected using the thermal camera so i am not 100% sure about this.
    Any ideas?
  • silver60618
    Macbook A2338 - Ripped off Trackpad Posts - No Keyboard/Trackpad function
    by silver60618
    Hi gang, I was hoping someone could help me. Im working on a A2338 Macbook, with torn off standoff posts for the connectors shield. The laptop works, but gets no trackpad/keyboard/haptic functions.
    It looks like it just sits on a ground plane. The PPBUS_AON Pins are recieving 12v, pp3v3 present. I dont see any traces going to these pads or near vicinity.
    Any ideas what I can check? Any help would be appreciated....
    03-16-2026, 05:46 PM
  • todordm
    Macbook A2338 / A2337 - Replace SSD
    by todordm
    There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
    01-17-2024, 03:55 AM
  • veedo
    Macbook A1534 problem with MacOs installation
    by veedo
    I have Macbook A1534 which had Windows 10 installed on it, now customer want to have macos back because windows is slow.
    From disk utility I deleted all partitions ( there was boot camp and macintosh ), created GUID Partition Map / APFS and I'm trying to install High Sierra from USB and its failing in half way, if I use Internet Recovery I have error apple.com/support -5101F, its shows me the option to go under support and mentions that battery have to be replaced.
    Because the battery I can't install the MacOs or it something else? any suggestions please?...
    01-13-2026, 03:29 PM
  • duwane
    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    by duwane
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
    10-26-2022, 07:02 AM
  • som_b1
    MacBook Pro a2141 not installing macOS
    by som_b1
    hello. I have 2141 on which I can't restore macOS. When loading, no buttons are active, it immediately wants to restore the Internet. But then I see an error 2100f. It doesn't boot from an external USB.
    I can't flash it through dfu because I don't know the version of macOS that was on it. Help
    By the way, for some reason it heats up inadequately and the coolers are at maximum
    08-04-2025, 03:49 AM
