Toshiba P70-A-12J - DA0BDBMB8F0
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    Hi.
    I have a Toshiba P70-A-12J - board DA0BDBMB8F0 that works fine on charger and battery at high loads. But if there is a high load, cpu or gpu on battery, it immediately shuts down. Tested with a new battery and 2 used ones..
    Any idea?
    Thanks.
  • pfmc82
    • Nov 2023
    • Portugal
    Re: Toshiba P70-A-12J - DA0BDBMB8F0
    Originally posted by ZOrd_Z
    Hi.
    Any idea?
    Thanks.
    I've the exact same issue with same model, you were able to find a clue?
    I'm tempted to throw the board into the oven and pray.
    It was already diagnosed around typical components with no luck
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
      by sam_sam_sam
      I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
      I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
      I tested the battery cells there are installed right now and they are testing good with no issues that I...
      02-04-2025, 08:08 PM
    • mkdj
      ASUS X571 no power : battery issue?
      by mkdj
      Mark and model: ASUS X571
      Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
      Tests already made:
      - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
      09-14-2023, 11:10 PM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
