820-3437 battery not detected
  • Borteck
    • Sep 2023
    • 8
    • France
    My MacBook Air 2014 A1466 EMC 2632 doesn't detect the battery anymore.
    The battery is new, almost... I changed it 3 months ago and it was working perfectly.
    Now, there is no more battery icon. In the system list, it looks like there is no battery at all... I've tried resetting PRAM and SMC several times with no change.
    With Magsafe2, the laptop is working, very slower than before.
    When plugged, green light is on - fan spins - fan stops - orange light - fan spins - fan stops -
    fan spins - start chimes.
    I've checked Q7155 with and without battery :
    No battery :
    source 1,2,3 : 8,5v
    gate 4 : 8,5v - 1,23v - 8,5v - 1,23v (change every second)
    drain 5 : 8,5v -> 2,3v
    With battery :
    source 1,2,3 : 8,5v
    gate 4 : 8,5v - 1,19v - 8,5v - 1,19v (change every second)
    drain 5 : 8,5v
    What do you think about the drain voltage without battery, it should be a steady 0v ?
  • mon2
    • Dec 2019
    • 14009
    Re: 820-3437 battery not detected
    Measure the voltage to ground of each pin on the battery connector while it is connected to the logic board.
    Post the measurements.
    Concern is with the voltage readings of the smbus pins which are the SCL and SDA pins.
    • MuertoGB
      • Sep 2021
      • 94
      • United Kingdom
      1.2v on the gate will indicate charging, 1.4v will indicate it's not charging. It sounds like the ISL doesn't like something. Slowness is throttling, most likely due to the battery not being detected. First step would probably be another battery. Is there any voltage on the battery, or has it cut off to 0v?
      I might also add that the gate cycling 1.2 > 8.6 > 1.2 is also indicitive of the battery not being detected on the SMBus.
      • Borteck
        • Sep 2023
        • 8
        • France
        Thanks a lot for the advices. Here are my measurements :
        MagSafe2 plugged -> orange
        Battery pins :
        1,2,3 : 8,5v (PPVBAT_G3H_CONN)
        4 : 3,4v (SMBUS SCL)
        5 : 3,4v (SMBUS SDA)
        6 : 0v (SYS_DETECT_L)
        7,8,9 : 0v GND
        • mon2
          • Dec 2019
          • 14009
          Source a known good battery from Amazon (risk free) and test again.
          • Borteck
            • Sep 2023
            • 8
            • France
            Sir, yes Sir.
            Already done Sir
            • reformatt
              • Feb 2020
              • 1400
              Battery is likely faulty. My experience is pretty poor with anything marketed as 'genuine', as they are anything but. An original Apple battery lasts years, but these replacements definitely do not. So 3 months old isn't entirely unexpected on some of these batteries.
              I have been using batteries specifically marketed as aftermarket with very good success.
              • Borteck
                • Sep 2023
                • 8
                • France
                You're definitly right, it was not a "genuine" one, clearly stated as Amazon after market.
                Beside that why my 2005 iPod Classic 5th gen 60Go "video generation" is still working with good geniune battery ?! Alomst 20 years
                Ok Amazon has accepted the exchange for my MBAir battery so we'll see how long the new one will last...
                • Borteck
                  • Sep 2023
                  • 8
                  • France
                  Hi !
                  You were right, again
                  Battery was the issue in the first place.
                  Being "Her Majesty Battery the IIIrd", so young in charge,
                  I was overthinking on a logic board problem.
                  Thanks for your precious help !
                  Cheers
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • mrkmpn
                    Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                    by mrkmpn
                    Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                    This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                    03-13-2024, 01:54 PM
                  • gboone
                    820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                    by gboone
                    Hi, I was given this laptop by my uncle who said:
                    • It would occasionally shutdown if not plugged in
                    • battery had been replaced
                    • touchbar would "strobe"
                    I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                    After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                    BUT
                    When powered off, it would at some point have a...
                    01-27-2025, 09:12 AM
                  • mkdj
                    ASUS X571 no power : battery issue?
                    by mkdj
                    Mark and model: ASUS X571
                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                    Tests already made:
                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                    - I have removed...
                    07-14-2025, 09:16 AM
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                    09-14-2023, 11:10 PM
