820-3437 battery not detected
  • Borteck
    • Sep 2023
    • 8
    • France
    My MacBook Air 2014 A1466 EMC 2632 doesn't detect the battery anymore.
    The battery is new, almost... I changed it 3 months ago and it was working perfectly.
    Now, there is no more battery icon. In the system list, it looks like there is no battery at all... I've tried resetting PRAM and SMC several times with no change.
    With Magsafe2, the laptop is working, very slower than before.
    When plugged, green light is on - fan spins - fan stops - orange light - fan spins - fan stops -
    fan spins - start chimes.
    I've checked Q7155 with and without battery :
    No battery :
    source 1,2,3 : 8,5v
    gate 4 : 8,5v - 1,23v - 8,5v - 1,23v (change every second)
    drain 5 : 8,5v -> 2,3v
    With battery :
    source 1,2,3 : 8,5v
    gate 4 : 8,5v - 1,19v - 8,5v - 1,19v (change every second)
    drain 5 : 8,5v
    What do you think about the drain voltage without battery, it should be a steady 0v ?
  • mon2
    • 14659
    Re: 820-3437 battery not detected
    Measure the voltage to ground of each pin on the battery connector while it is connected to the logic board.
    Post the measurements.
    Concern is with the voltage readings of the smbus pins which are the SCL and SDA pins.
    • MuertoGB
      • Sep 2021
      • 94
      1.2v on the gate will indicate charging, 1.4v will indicate it's not charging. It sounds like the ISL doesn't like something. Slowness is throttling, most likely due to the battery not being detected. First step would probably be another battery. Is there any voltage on the battery, or has it cut off to 0v?
      I might also add that the gate cycling 1.2 > 8.6 > 1.2 is also indicitive of the battery not being detected on the SMBus.
      • Borteck
        • Sep 2023
        • 8
        • France
        Thanks a lot for the advices. Here are my measurements :
        MagSafe2 plugged -> orange
        Battery pins :
        1,2,3 : 8,5v (PPVBAT_G3H_CONN)
        4 : 3,4v (SMBUS SCL)
        5 : 3,4v (SMBUS SDA)
        6 : 0v (SYS_DETECT_L)
        7,8,9 : 0v GND
        • mon2
          • 14659
          Source a known good battery from Amazon (risk free) and test again.
          • Borteck
            • Sep 2023
            • 8
            • France
            Sir, yes Sir.
            Already done Sir
            • reformatt
              • Feb 2020
              • 1488
              Battery is likely faulty. My experience is pretty poor with anything marketed as 'genuine', as they are anything but. An original Apple battery lasts years, but these replacements definitely do not. So 3 months old isn't entirely unexpected on some of these batteries.
              I have been using batteries specifically marketed as aftermarket with very good success.
              • Borteck
                • Sep 2023
                • 8
                • France
                You're definitly right, it was not a "genuine" one, clearly stated as Amazon after market.
                Beside that why my 2005 iPod Classic 5th gen 60Go "video generation" is still working with good geniune battery ?! Alomst 20 years
                Ok Amazon has accepted the exchange for my MBAir battery so we'll see how long the new one will last...
                • Borteck
                  • Sep 2023
                  • 8
                  • France
                  Hi !
                  You were right, again
                  Battery was the issue in the first place.
                  Being "Her Majesty Battery the IIIrd", so young in charge,
                  I was overthinking on a logic board problem.
                  Thanks for your precious help !
                  Cheers
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • mrkmpn
                    Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                    by mrkmpn
                    Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                    This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                    03-13-2024, 01:54 PM
                  • gboone
                    820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                    by gboone
                    Hi, I was given this laptop by my uncle who said:
                    • It would occasionally shutdown if not plugged in
                    • battery had been replaced
                    • touchbar would "strobe"
                    I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                    After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                    BUT
                    When powered off, it would at some point have a...
                    01-27-2025, 09:12 AM
                  • mkdj
                    by mkdj
                    Mark and model: ASUS X571
                    Tests already made:
                    - I have removed...
                    07-14-2025, 09:16 AM
                  • grimacelord
                    A2338 820-02020-A | Battery Not Detected/Random Reboots
                    by grimacelord
                    I have a A2338 MacBook Pro here that came to me because the battery wasn't being detected. The owner tried to replace the battery themselves thinking that the battery was the problem but the behavior continues even with their new aftermarket battery. They also accidentally ripped off the black plastic clasp to the battery flex cable connector @ J5151, but I pulled that off of a donor board and replaced that for them already. I did quickly check to see if that was simply the problem, but it's not.
                    First thing I checked was I2C_SMC_PWR_3V3_SCL and I2C_SMC_PWR_3V...
                    07-22-2025, 09:11 AM
