HP G62 Model G62-b50SG TIC sound
  • samtron786
    • Aug 2016
    • 154
    • germany
    Hello
    You can see some voltages as 3.3V, but 19V is not stabilized and rises and falls with each blink
    The Power LED button will flash and you can hear a TIC sound with each flash.
    where does the TIC sound come from?
    Thank you
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP G62 Model G62-b50SG TIC sound
    There is some short on your motherboard. measure resistance to GND on all coils as well as CLR.
    • samtron786
      • Aug 2016
      • 154
      • germany
      I found the problem
      PQ55 Mosfet replaced now turns on but turns off again after 10 or 20 seconds later
      PQ55
      D=9.80V
      G=19V
      S=19V
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Do you get display on screen ? Is your motherboard with ati graphics chip? mention mb part number like DAX1....
        • samtron786
          • Aug 2016
          • 154
          • germany
          PM_A_HPC_S_MV_MB_V1
          Yes, it starts normally
          • samtron786
            • Aug 2016
            • 154
            • germany
            Another question: where does the sound come from the coil or electrolytic capacitors?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Its difficult to pinpoint the source of ticking sound in such cases as whereever you put yours ears,it'll always confuse you. Model is with discrete graphics or not? Resistance to GND on all coils? These were highlighted earlier but you didnt answered them.
              • samtron786
                • Aug 2016
                • 154
                • germany
                This is the motherboard pictures
                here 3 coils beep and the values from both sides
                75,8 75,8
                13,8 13,8
                12,6 12,6
                • samtron786
                  • Aug 2016
                  • 154
                  • germany
                  P/n :01013tm00-600-g rc8f32003ah1
                  the fan can rotate
                  • samtron786
                    • Aug 2016
                    • 154
                    • germany
                    What do you have to do when something like this happens?
                    cmos reset 502, then the laptop turns off and no longer starts, you have to wait a day
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      This board is too old to waste your time. It has a discrete amd graphics as well which invariably fails after so many years.
                      • samtron786
                        • Aug 2016
                        • 154
                        • germany
                        Yes, it has an ATI graphics chip
                        When I start the laptop the fan also turns
                        the coils don't all beep
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Northbridge is also well known for being unreliable.
                          Best solution is to replace motherboard (+CPU and heatsink) with an Intel platform without dGPU. There are a few Intel boards for G62 but not sure which one would fit exactly your chassis, possibly the PM_I_HPC_S MV_MB_V3.
                          Also gives better performance, battery life and less heat.
                          • samtron786
                            • Aug 2016
                            • 154
                            • germany
                            OK thanks
                            Battery is also being charged
                            then I have to see if I can find another motherboard
                            • nickgronk
                              iMac PowerPC G4 very low sound • Sunflower Model
                              by nickgronk
                              Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
                              I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
                              I cannot find any schematics...
                              08-05-2024, 07:04 AM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
