820-00165 all_sys_pwrgd low
    I have a Macbook 820-00165. Customer said it isnt turning on. When it came to me it turned on just once for sometime and the dead.
    Upon inspection i found corrosion at R8159 R8158 R8151 R8152.
    Replaced them. Still no success.
    I checked all the Power Rails.
    I am getting PM_SLP_S3_BUF_L 3.3V at R8167 but ALL_SYS_PWRGD is at 0.6V. Thought it looked fine i replaced R8167 too.
    Checked from crap below Q8150 as the corrosion was below it. But nothing there too.
    Macbook is drawing around 180Amps.
    Re: 820-00165 all_sys_pwrgd low
    What are the diode mode readings on each pin on Q8150?
      Red to Ground
      Pin#7 is 7.5K Ohms
      Pin#6 is 160K Ohms
      Pin#5 is 15.75K Ohms
      Pin#4 is 1.5M Ohms
      Pin#3 is 1.1k Ohms
      Pin#1 is 20.7k Ohms
        ALL_SYS_PWRGD is pulled high by PM_SLP_S3_BUF_L via R8167. It can be pulled low via Q8150 or via open drain power good lines from each of these power rails;
        P1V8S3
        P5VS4RS3
        P1V05S0
        DDRREG --> PP1V2_S3
        Check each supply for shorts/presence, especially P1V8S3 at L7820
          P1V8S3
          P5VS4RS3
          P1V05S0
          DDRREG --> PP1V2_S3
          Removed Q8150. Issue Solved
