820-00165 all_sys_pwrgd low
  • Instafixx
    • Jul 2022
    • 374
    • India
    I have a Macbook 820-00165. Customer said it isnt turning on. When it came to me it turned on just once for sometime and the dead.
    Upon inspection i found corrosion at R8159 R8158 R8151 R8152.
    Replaced them. Still no success.
    I checked all the Power Rails.
    I am getting PM_SLP_S3_BUF_L 3.3V at R8167 but ALL_SYS_PWRGD is at 0.6V. Thought it looked fine i replaced R8167 too.
    Checked from crap below Q8150 as the corrosion was below it. But nothing there too.
    Macbook is drawing around 180Amps.
  • MuertoGB
    • Sep 2021
    • 94
    Re: 820-00165 all_sys_pwrgd low
    What are the diode mode readings on each pin on Q8150?
    • Instafixx
      • Jul 2022
      • 374
      • India
      Red to Ground
      Pin#7 is 7.5K Ohms
      Pin#6 is 160K Ohms
      Pin#5 is 15.75K Ohms
      Pin#4 is 1.5M Ohms
      Pin#3 is 1.1k Ohms
      Pin#1 is 20.7k Ohms
      • reformatt
        • Feb 2020
        • 1497
        ALL_SYS_PWRGD is pulled high by PM_SLP_S3_BUF_L via R8167. It can be pulled low via Q8150 or via open drain power good lines from each of these power rails;
        P1V8S3
        P5VS4RS3
        P1V05S0
        DDRREG --> PP1V2_S3
        Check each supply for shorts/presence, especially P1V8S3 at L7820
        • Instafixx
          • Jul 2022
          • 374
          • India
          P1V8S3
          P5VS4RS3
          P1V05S0
          DDRREG --> PP1V2_S3
          Removed Q8150. Issue Solved
          • narf
            Epson EB-U42 projector / Caps with 0.7 ohms ?!
            by narf
            hi all,
            first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
            i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
            what i've found so far:
            - the PSU does its job and supplies 12V to the mainboard via the connector.
            - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
            - not far away, there's the first cap with a resistance of 0.7 ohms....
            07-02-2024, 03:53 PM
          • gica69
            Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
            by gica69
            I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
            Resistor shows orange range silver gold and green lines.
            Thanks in adv...
            07-21-2025, 09:49 PM
          • applejuice95
            A2485 - No Backlight - 820-02100
            by applejuice95
            Have functional A2485 unit, all things work but backlight is out.
            There was some liquid corrosion around UP800's Caps and Res(s) - Cleaned all well . No change.
            I measured resistance to ground of all UP800s surrounding components on another working board.
            The components that are not correct on this board, with backlight out are:
            CP810 - should have 250K resistance at Pin 1, its reading 80 Ohms
            CP811 - Should have 25K at Pin 1, its reading 80 Ohms
            RP805 - Should be 30K on both Pin 1 & 2 - Pin 1 is 50Ohms and Pin 2 is 200ohms...
            02-24-2025, 11:49 AM
          • B2L_Repairs
            Huawei D15 no power found corrosion damage
            by B2L_Repairs
            I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
            02-06-2025, 01:05 PM
          • Sephir0th
            DELL XPS 15 9560 - No VCore, Power Off after few seconds
            by Sephir0th
            Hello Community,
            i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
            It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
            Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
            I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
            05-09-2021, 11:22 AM
