A2289 No PPBUS_G3H
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    A2289 No PPBUS_G3H
    PPBUS_G3H is shorted. Injected voltage at F7000
    There is a short but no short is present, so went ahead and tested restistors on ISL9240 area All resistors are in 5% range of 1OHM. Replaced the ISL9240 and still no power.
    5Volts .03Amps
    Went ahead and replaced both CD3217 chips, still same issue. tried injecting voltage again but nothing is happening. Would like a little direction.
    Checked CHGR_MVR_EN and it is not present, but what is odd is I just replaced the ISL9240 and that still didn't bring it back. Replaced it again with another we had in stock assumed it was bad, still no CHGR_MVR_EN
    This one is kind of making me feel MEH. I fixed one exactly like this today and now this new one is breaking my balls lol. Same issue it seems but seems to not want to turn on and get pass 5v .03Amps.
    just want to add.
    I'm seeing 5v .03 amps then the amps drop to 0.00 then jump back to .03amps every second
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • Dec 2019
    • 14369
    Re: A2289 No PPBUS_G3H
    Remove F7000 and power up again to test PPBUS_G3H.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Removed F7000
      0Volts on PPBUS_G3H
      sigpic
      • mon2
        • Dec 2019
        • 14369
        0 volts on both sides of the removed fuse?
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          0Volts on PPBUS_G3H
          12Volts ons PPVBAT_G3H_CHGR_REG
          I also did check the fuse and it is not blown
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 667
            bump
            sigpic
            • mon2
              • Dec 2019
              • 14369
              What is the resistance to ground of PPBUS_G3H (without F7000)?
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 667
                3 to 3.5 ohms without F7000 on PPBUS_G3H
                sigpic
                • mon2
                  • Dec 2019
                  • 14369
                  Inject 1 volt onto this downstream rail and check who heats up. Likely a cap and hope not the CPU. Do not increase the voltage
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 667
                    you want me to inject 1volt 5 amps into PPBUS_G3H?
                    Because if so I did that with the F7000 fuse removed, shows signs of short still, nothing on the thermal gun or ouchy test. Sprayed isopropyl all over nothing shows short on the board. I keep leaning towards the ISL9240 but I just replaced it three times. There is no way 2 new ISL were bad out the box.
                    sigpic
                    • mon2
                      • Dec 2019
                      • 14369
                      Yes. This is the downstream (consumer) side of the removed fuse. This is the side showing a partial short of a component. As you do this injection, the shorted part will heat up. Often a tantalum capacitor that will crack open under the pressure.
                      If the high side mosfet of the CPU rail is shorted, then the CPU will heat up and it is game over since the CPU replacement requires proper bga rework tools.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 667
                        Yeah injected voltage 1 volt into PPBUS_G3H with fuse removed. CPU does not heat up. Nothing is heating up. I am assuming ISL9240 is still bad?
                        sigpic
                        • mon2
                          • Dec 2019
                          • 14369
                          Is the CPU with a heatsink? If yes, it may be dissipating the heat.
                          Q: while injecting, what is the current consumption of your power supply?
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 667
                            Removed Heatsink, no increase in heat.
                            When voltage is injected consumption is .239 Amps at 1Volt. Shows a short basically.
                            sigpic
                            • mon2
                              • Dec 2019
                              • 14369
                              Remove all power. Measure the resistance from the same PPBUS_G3H to PPVCC_S0_CPU = Vcore for the CPU. Checking to see if the high side mosfet is shorted. Does not appear to be the case.
                              If clear, then we can consider to increase the voltage.
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 667
                                I am getting 1 ohm and dropping a little around .5 ohms to 1.0 ohms at PPVCC
                                sigpic
                                • mon2
                                  • Dec 2019
                                  • 14369
                                  To be clear, you are measuring the resistance between the PPBUS_G3H pad and the other meter probe is @ PPVCC_S0_CPU ?
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 667
                                    Yes
                                    PPBUS_G3H (F700) to PPVCC_S0_CPU (C1027)
                                    Correction.
                                    4OHMS at C1027
                                    sigpic
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 667
                                      Unless I was checking wrong should I be checking a specific cap for this area? Kind of lost me there apologies
                                      sigpic
                                      • mon2
                                        • Dec 2019
                                        • 14369
                                        Inject the 1 volt again @ F7000. Measure with care the voltage to ground @ C1027. Do you see a voltage @ C1027 ?
                                        Concern here is that the high side mosfet may be defective and respectively, the high voltage of PPBUS_G3H has killed the CPU.
                                        PS: You will need to grow a few extra arms.
                                        • Flasman90
                                          Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
                                          by Flasman90
                                          Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
                                          My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
                                          What I have done so far:
                                          - All of the routine diagnostic methods including...
                                          Today, 08:38 AM
                                        • baglaivlad
                                          MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                                          by baglaivlad
                                          Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                                          Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                                          01-09-2024, 09:55 PM
                                        • Grandoni Manuel
                                          MacBook a2289 water damage
                                          by Grandoni Manuel
                                          Hello to all ! I follow you but this is first time write !!
                                          your forum is the best !!
                                          so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
                                          now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
                                          q8400
                                          q8401
                                          D8410
                                          and the resistor R8431
                                          if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
                                          on...
                                          04-03-2025, 06:45 PM
                                        • jasonr2000
                                          MacBook Pro A2289 No Power
                                          by jasonr2000
                                          hi guys I have a 2020 MacBook Pro A2289 it has the i5 CPU and is now acting as if its dead,
                                          when I plug in the charger cable with a volt meter thing connected as well its drawing 20.3v and 1.11A
                                          if I press the power button nothing happens.
                                          but if I hold the power button for 7 seconds or more the voltmeter drops all the amps down to 0.00A but voltage stays the same.
                                          any ideas where I can check ??
                                          from what I can gather it must be charging the battery at 1.11A as nothing happens when the power button is pressed. I can successfully...
                                          03-08-2025, 10:22 AM
                                        • AlexVG
                                          Macbook A2289 820-01987A no backlight
                                          by AlexVG
                                          Hi everybody,
                                          I have Macbook A2289 820-01987A.
                                          It have had 1.8V short circuit problem that I fixed.
                                          But after 20 minutes working the backlight went out.
                                          I found out missing of EDP_BKLT_EN going to U8400 from U0500.
                                          Ground down level goes from U0500. (I tread to remove R8442).
                                          The machine starts perfect. I can watch image on the screen with a flashlight, and it works with the external screen.
                                          Do you have any suggestions what kind of problem I came across?
                                          Thank you in advance....
                                          02-12-2025, 06:48 PM
