A2289 No PPBUS_G3H
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: A2289 No PPBUS_G3H
    No Voltage at C1027 when injecting 1Volt at F7000 PPBUS_G3H
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • mon2
      • 14660
      To me, it appears to be safe to inject a higher voltage to see if someone heats up. Consider increasing the voltage slightly. To rephrase, the CPU high side mosfet does not appear to be leaking. If it was, then the CPU is probably already dead.
      Injection would be much like 'beating a dead CPU'.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Should I increase it to 2volts. I know 5Volts will fry the CPU for sure. a sweetspot would help to inject more voltage I would hate to fry the CPU at this point. I know I am so close to repairing this but its just a simple short somewhere that needs to be found.
        sigpic
        • harp
          • Jun 2022
          • 642
          • Planet Earth
          Originally posted by Stephen
          you want me to inject 1volt 5 amps into PPBUS_G3H?
          Because if so I did that with the F7000 fuse removed, shows signs of short still, nothing on the thermal gun or ouchy test. Sprayed isopropyl all over nothing shows short on the board.
          Always use current limit on your psu - first start with lover current and gradualy rise up. Observe voltage drop on psu and calculate output power - when you rich about 1w or so, you can spot thermal difference, and no point to go higher.
          Alcohol is not good in this type low power scenario, because you can not spread it evenly thichness, and with evaporation he cooled board significaly, masking your short.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            After further investigation with lighter voltage the CPU is increasing in heat. I am assuming this is the culprit
            sigpic
            • Flasman90
              Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
              by Flasman90
              Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
              My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
              What I have done so far:
              - All of the routine diagnostic methods including...
              08-29-2025, 08:38 AM
            • baglaivlad
              MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
              by baglaivlad
              Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
              Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
              01-09-2024, 09:55 PM
            • Flasman90
              Macbook Pro A2289 - 820-01987 - Low ALL_SYS_PWRGD
              by Flasman90
              Hi all, I'm working on an an A2289 which had a previous spill that was repaired. Now upon turning on the only signs of life are the trackpad and fans spinning. I succesfully performed a DFU restore, but after completion it did not boot into recovery mode and display still is not turning on (It didnt turn on during the DFU restore, as I believe you would expect to see the apple logo at some point?).
              I have removed the logic board as well as the usb-c charging port and plugged the charger in and taken the following readings, which show that ALL_SYS_PWRGD is low at 1.78V. I took measurements...
              09-02-2025, 10:47 AM
            • Grandoni Manuel
              MacBook a2289 water damage
              by Grandoni Manuel
              Hello to all ! I follow you but this is first time write !!
              your forum is the best !!
              so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
              now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
              q8400
              q8401
              D8410
              and the resistor R8431
              if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
              on...
              04-03-2025, 06:45 PM
            • jasonr2000
              MacBook Pro A2289 No Power
              by jasonr2000
              hi guys I have a 2020 MacBook Pro A2289 it has the i5 CPU and is now acting as if its dead,
              when I plug in the charger cable with a volt meter thing connected as well its drawing 20.3v and 1.11A
              if I press the power button nothing happens.
              but if I hold the power button for 7 seconds or more the voltmeter drops all the amps down to 0.00A but voltage stays the same.
              any ideas where I can check ??
              from what I can gather it must be charging the battery at 1.11A as nothing happens when the power button is pressed. I can successfully...
              03-08-2025, 10:22 AM
