when i remove cpu i get all voltages except vcc core,so when i put cpu all voltages are missing exept 3.3v /5v and run step,so I changed cpu without result.i don't know how to resolve this issue. can anybody help
DA0R09MB6H1 shut down
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by mosfetratusWhen i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
Works with battery and charges, but when i shut off i get this problem.
It had liquid spill. Board has no corrosion, keyboard is working, power button... -
by panossIn the above mentioned monitor, I removed the plug a few times and this resulted no power.
I opened it, soldered the dc jack and worked again.
But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
IC600 (D9329)
pin 1 (BST) 9.6V
pin 2 (VIN) 13.5V
pin 3 (SW(Switching output)) 4.8V
pin 7 (EN)
pin 8 (SS) 2.6V
IC601...-
by ivtecHi guys; i have installed win 10 Home Edition from a DVD iso and it changed to Win pro ,how i change it back to Home edition without reinstall again ?Thanks
- Loading...
