HP Omen 16 no display
  • barria98
    barria98
    • Jan 2024
    Any luck with this? I seem to be having a similar issue with an Omen 17.3
    • guyandpit
      • Oct 2021
      • 77
      • Philippines
      up for this
      • hrundel200
        • Jan 2024
        • 4
        • CA
        HP OMEN 16-b0075TX motherboard DA0G3KMBCG0 today its happening to me, Power ON, LED ON, Screen OFF (Black)
        all possible tricks from Internet are not working, from HP -> go to nearest Service Center !
        How to fix it ? any ideas ?
        Thnx
        • guyandpit
          • Oct 2021
          • 77
          • Philippines
          Thnx
          hi same also with me, btw have you tried to connect in monitor using hdmi? no keyboard light? or caps lock light? thank you
          • BalkanBoy
            • Feb 2017
            • 69
            • Croatia
            When you say 1.8V IC is overheating, what do you mean by that? Have you got thermal camera? How hot is it? Also 10V you marked on 1st photo, on cap, that's with battery connected I assume?
            • hrundel200
              • Jan 2024
              • 4
              • CA
              #26
              Both screens, either LCD or via HDMI are BLACK with no signs of light.
              Keyboard is working, fans are spinning.
              I tried to disconnect battery, pressed Power button for 1 min, swap RAMs, restart it, and nothing.
              Anybody knows, where I can buy NEW motherboard ?
              • fhulgzz
                FotoCloudz
                • Sep 2020
                • 15
                • Philippines
                #27
                Hi I manage to solve this issue. After testing all the voltage found out its all normal.
                It wasn't a bios problem also because I tried so many versions, even my back-up doesn't work.
                So i have a hunch that it maybe a cold solder.
                So I reball/resolder the 1.8v regulator since this is the one overheating. I also refresh the solder of the legs of the SIO and that is all. It works.
                Click image for larger versionName:	IMG_20240115_133233.jpgViews:	35Size:	4.76 MBID:	3178774
                • guyandpit
                  • Oct 2021
                  • 77
                  • Philippines
                  #28
                  Sir Is this the ic you reball near in the wifi card? Thank you
                  • hrundel200
                    • Jan 2024
                    • 4
                    • CA
                    #29
                    Dude, could you show on the diagram what exactly you soldered?
                    • hrundel200
                      • Jan 2024
                      • 4
                      • CA
                      #30
                      @fhulgzz​ can you pls teply on my post ?
                      • trepachka
                        • Oct 2022
                        • 424
                        I have this model in my hands right now. Thank you for very much for clear photos of the motherboard with voltage markings, by the way. Currently, the computer charges but does not post. When pressing the power button, it lights up briefly, then goes off. The motherboard does not have any shorts I can find. The 5V Always rail is present. However, the 3.3V Always rail is not present. Under the infrared camera, the chip responsible for it is the only bright spot on the motherboard. I do get 3.3V on many pins of the EC chip. But, I think this voltage is generated by auxilary rails.
                        Because the schematics is not available for this model, could you help me identify the chip? It has "LE=BG" etched on it. Thank you.
                          • 20895
                          RT6258B - https://www.badcaps.net/forum/troubl...d-marked-le-8e
                          https://www.badcaps.net/forum/troubl...19#post1482819
                          • trepachka
                            • Oct 2022
                            • 424
                            Great. So, it's a 3.3V step-down converter ("B" vs "C" at the end). It's not shorted but definitely messed up. I will see if I could get one purchased. Thanks.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              If 3V regulator IC is heating up,always check resistance to GND on LDO pin.
                              5V ALW will be present on standby and 3v ALW will come up after power button on this platform.
                              • yawning_fire
                                • Jun 2025
                                • ireland
                                #35
                                hi what pins jump start motherboard?
                                • sikocan
                                  • Oct 2019
                                  • 344
                                  See which pin shorts to ground when power button pressed on the keyboard connector pins.
