Macbook 820-00165 will not fully boot
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste.
    I have a Macbook A1466 820-00165. The machine boots up. Chimes. Apple Logo.
    Progress Bar.
    It comes to the login screen and then after 3 seconds it turns off.
    If i press the on/off key it ll again turn on and then turn off the same way.
    No corrosion on the board.
    Tried removing the SSD and booting. Same issue. The question mark folder will appear and it ll turn off.
    After it turns off i still have a stable PPBUS_G3H and PP3V42 etc.
    What can be the issue?
  • mon2
    • 14659
    Re: Macbook 820-00165 will not fully boot
    https://www.it-tech.com.au/how-to-re...halfway-issue/
    • Instafixx
      • Jul 2022
      • 374
      • India
      Let me check this out. But my machine doesnt even boot into the Apple Diagnostics Mode. It ll switch off half way.
      • Instafixx
        • Jul 2022
        • 374
        • India
        The parameters don't suggest a failed Q1920.
        When the fan is on i am getting power supply of Q1920
        PP PP5V_S0 1V5_S0SW_AUDIO_HDA and PP5V_S0
        But when fan goes off these rails are 0V.
        • ACS-Repair
          • Feb 2021
          • 204
          I've had a couple of these 820-00165 that would either kernel panic at startup or crash every 10 minutes after starting up. I have not been able to solve the one with the kernel panic but I found some components broken off the board on the latter.
          Specifically, I found R2281 was not present and after restoring it, the computer no longer crashes. If the board has always been in the computer it may not be likely that components are missing, but if you don't know the history of the board it's always a good idea to scan for missing parts.
          • Instafixx
            • Jul 2022
            • 374
            • India
            I found no component missing as such. But while cleaning the board 2 caps fell out. Put those back in place. Thats it. The board has no history it seems . I am totally stuck here
            • mon2
              • 14659
              Try booting with a SMC BYPASS.
              • Instafixx
                • Jul 2022
                • 374
                • India
                It is not happening.
                Tried SMC Bypass.
                Tried Safe Mode.
                Its still the same.
                It boot up.
                Login screen appears.
                Fans becomes fast and it goes off.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  One of the components that fell off was R5117 which is the CPU_THRMTRIP_3V3 line resistor.
                  Not an expert but the name suggests that it is thermal monitor of the cpu and will trip the cpu when too hot?
                  Is that the case with my Macbook as the fan becomes fast before switching off as if the machine becomes too hot.
                  When the fan is spinning and the machine is booting up
                  CPU_THRMTRIP_L is at 0.02V.
                  When the fan stops and the machine is off
                  CPU_THRMTRIP_L jumps to 3.3V.
                  [UPDATE]
                  Removed the Heat Sink and found that the CPU is indeed getting really hot when the Machine Starts.
                  • Instafixx
                    Macbook A1278 Does not fully boot
                    by Instafixx
                    Namaste.
                    I have a Macbook A1278 that doesnt fully boot up. I get the loading bar and it just becomes gray.
                    Tried changing the SSD Cable and SSD. It does an external boot though.
                    The board number is 820-2936.
                    Did some random checking but all seems to be fine. Any leads as to what can be the problem?
                    01-30-2023, 07:33 AM
                  • No Lan
                    [Macbook pro A1708] [Boot loop] [Trackpad ?]
                    by No Lan
                    Hey everyone,
                    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                    05-24-2025, 03:09 PM
                  • twonk9098
                    Macbook Pro mid 2015 battery required to boot?
                    by twonk9098
                    I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                    The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                    This model has the newer trackpad which is not clickable when turned off.
                    At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                    If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                    12-10-2024, 06:51 PM
                  • veedo
                    Macbook A2442 820-02098 boot and display issue
                    by veedo
                    Hi All
                    I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                    Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                    I found component UD290 ( SF0101-I2C) little...
                    04-01-2024, 06:06 AM
                  • PITERPENY
                    Macbook A2251 no boot
                    by PITERPENY
                    The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
                    01-05-2025, 03:11 PM
