MacBook Air A1932 820-01521 no boot 5v only
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I've one MacBook Air a1932 board number 820-01521
    it's stuck on 5v (0.03 - 0.4a) - I've replaced 2x CD3215 for know good ones. It's still on 5V only and when I connect it to another MacBook it's just connecting and disconnecting.
    I've checked PPBUS_G3H and the voltage it's not stable (it's still going up and down)
    is there any voltage regulator ? or what should I check ?
    I've also checked diode mode PPBUS_G3H on test point near CD3215 and I get 0,474
  • mon2
    • Dec 2019
    • 14340
    Re: MacBook Air A1932 820-01521 no boot 5v only
    Each cd3215 must be working to dial up the 20v power delivery contract from the power adapter.
    Check the voltage to ground of each LDO rail on each cd3215.
    Remove the fuse on PPBUS_G3H. Power up again and measure the voltage to ground of the producer side (ISL) of the removed fuse.
    Post each measurement. Start with the fuse removal.
    Is PPBUS_G3H voltage now stable without the fuse?
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      I've removed F6700
      on one side of the fuse point it's still jumping ...
      voltage on PPBUS_G3H is still not stable still jumping 6v,7v,11v,12v
      XA_LDO and XB_LDO both have 0v
      • mon2
        • Dec 2019
        • 14340
        Measure the voltage to ground of PP3v3_UPC_XA_LDO and PP3v3_UPC_XB_LDO.
        Remove all power and configure meter into resistance mode.
        Measure the resistance to ground of each, PP3v3_UPC_XA_LDO and PP3v3_UPC_XB_LDO.
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          ok I've tested both and they look ok (XB I've tested on test point, XA I've tested on C3108)
          PP3v3_UPC_XA_LDO - 9Mohm (and going down)
          PP3v3_UPC_XB_LDO - 9Mohm (and going down)
          • mon2
            • Dec 2019
            • 14340
            Resistance is fine but you really need to post the requested values. Otherwise, no one can help.
            • obelix24
              • Jun 2023
              • 291
              • Slovakia
              what values ? voltage I got 0v there
              • obelix24
                • Jun 2023
                • 291
                • Slovakia
                I have another MacBook Air same board that is probably more fixable.
                I get on it 20V but 0a (when everything is disconnected) if I connect battery the A go up to approx 1,5A.
                Strange is that PPBUS_G3H is present 12,64V but when I check it on L7030 I'm getting only 10V there (but it should be 12,64V)
                • mon2
                  • Dec 2019
                  • 14340
                  Hi. Not an issue. As long as PPBUS_G3H is stable, the inductor @ L7030 is doing its job. The switching regulator is pulsing on/off to dial up the target voltage. So the PPBUS_G3H is working as it should.
                  The spike of a stable current draw is of concern and often means some component is shorted or is partially shorted.
                  • obelix24
                    • Jun 2023
                    • 291
                    • Slovakia
                    where should I search for a short ? Inject voltage somewhere ?
                    I've checked board under microscope but I'm not able to find any blown component or anything obvious.
                    • mon2
                      • Dec 2019
                      • 14340
                      Something does not look right if you are reading 0A current draw yet you have PPBUS_G3H voltage rail.
                      How is the current draw being measured? Is it a USB Type-C meter? Be sure that the meter is bidirectional in design. We know that we picked up at least 1 meter from Aliexpress that is unidirectional so it reports 0A current draw due to the way it is connected to the power source and the load.
                      Post a pic of the USB-C meter. Also review if there are arrows on the opposide side of this tool. If the meter is used in reverse, the meter will not properly report the current draw.
                      • obelix24
                        • Jun 2023
                        • 291
                        • Slovakia
                        I'm measuring on USB-C meter (KEWEISI)
                        see photos both ports from both sides
                        • obelix24
                          • Jun 2023
                          • 291
                          • Slovakia
                          ok I've checked :
                          PPBUS_G3H - 12,64V
                          PP3v3_G3H_RTC - 3,3V
                          PP3v3_G3H - 3,3V
                          PP1v8_SLP_S2R - 1,8V
                          PP1v8_AWAKE - 1,8V
                          PP1v8_SLPS2R_PMUGPIO - 1,8V
                          PP1v1_SLPS2R - 1,1V
                          PP0v8_SLPS2R - 0,8V
                          PP0v82_SLPDDR - 0,82V
                          PP3v3_AWAKE - 3,3V
                          PPVDDCPUSRAM_AWAKE - here I have only 0,8V according to repair wiki there should be 1,06V
                          I've also noticed that now board is taking 0,03A
                          any idea ? it is probably not good to inject voltage here ...
                          so it looks like according to repair wiki that this problem is connected to corrupted T2 (revive via another Mac OS not working as it just ends with padlock icon), restore the same.
                          or corrupted NAND (as I have on board only one NAND it's probably not only replacing NAND with another - or is it so simple ?
                          Or I can try to replace U7800 with another one ? does this make any sense ?
                          • mon2
                            • Dec 2019
                            • 14340
                            Yes, agree with the repair wiki details for 'No Power 20v, ~0.03-0.06a' case.
                            Wait on other comments as I do not have experience in this area of repair...yet.
                            • obelix24
                              • Jun 2023
                              • 291
                              • Slovakia
                              Anyone else any idea ?
                              • jma46
                                • May 2020
                                • 24
                                Hi has repair wiki disappeared? I had it saved as a tab but nothing there?
                                • Admin
                                  • Oct 2003
                                  • 5334
                                  • United Kingdom
                                  Hi jma46, is this part of Badcaps forum or an external link? I've been tidying empty older groups so just a bit worried i've deleted something required. Can you clarify?
                                  • mon2
                                    • Dec 2019
                                    • 14340
                                    Noted the same a few days ago but it appears that the repairwiki website has been upgraded so the links have changed but content is still up there.
                                    Found the following for the older content:
                                    https://old.repair.wiki/w/Repair_Wiki
                                    • Cemal Odabasioglu
                                      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                      by Cemal Odabasioglu
                                      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                      Observations...
                                      01-14-2025, 03:54 PM
                                    • bouch
                                      unlock macbook air A1932 2019
                                      by bouch
                                      hi
                                      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                      I need help or information?
                                      Does anyone have the minat2 activator 1.4 software?
                                      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                      Thank yo...
                                      03-12-2025, 10:14 AM
                                    • No Lan
                                      [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                      by No Lan
                                      Hey everyone,
                                      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                      05-24-2025, 03:09 PM
                                    • twonk9098
                                      Macbook Pro mid 2015 battery required to boot?
                                      by twonk9098
                                      I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                                      The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                                      This model has the newer trackpad which is not clickable when turned off.
                                      At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                                      If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                                      12-10-2024, 06:51 PM
                                    • TOMÁŠ
                                      MacBook Air A1932
                                      by TOMÁŠ
                                      Hi, I've never worked with a MacBook before, so I need some advice.
                                      I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                                      05-20-2025, 11:19 AM
