Dell la-j081p charging issue
  • ahmarzo
    • Mar 2015
    • 171
    • india
    Have a Dell laptop la-j081p with charging ic intersil 95522h laptop works ok with adapter but the battery charging keeps on decreasing on AC adapter and it doesn't charge up.i have charged the battery in another laptop .please guide me how to find a solution for this problem
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Dell la-j081p charging issue
    First i would check dcin mosfets for internal short , then i would check if the adapter is recognised in bios.
    Then we can go further can you give us link to shematics.
    Good luck
    • ahmarzo
      • Mar 2015
      • 171
      • india
      Thanks for reply
      Dcin mosfets are ok no shorting on both mosfets and adapter shows 90w I have tried another adapter and it is detecting fine.but I got no voltage at prb02.and no voltage at pqb11 and pqb12 gates .ac ok is 3v and plz guide me where to check for fault and this is a new charging ic for me
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Still give us the measurements of PQB11/12 between(meter in 200K scale or higher)
        S-G
        S-D
        G-D
        PDB01-voltage on all pins with adapter only.
        • fah
          • Nov 2016
          • dubai
          La-j081p
          charging issue
          130w adapter charging ok, but
          45w,65w,90w adapter NOT INSTALLED error.
          i want to that 65 / 45 watt ,so what i do?
          expert explain me pls
          thank you
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Use the official rated charger and then measure PS_ID circuit. Share values.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • CIT
              Charging Issue on Dell G3 3579 (LA-F611P)
              by CIT
              Hi guys,
              I am working on a Dell G3 3579, with motherboard LA-F611P that is not charging.
              Unit was dead with blown PU01 and I replaced PU01 along with PUB02 to get the unit going. After testing I found the unit is not charging.
              I have seen this on the Dell G3 3579 on about 5 different units, but I have never been able to fix it
              So I can see in the bios its not a charger detection issue, as it is detecting my 130w charger fine, but even when plugged in the battery will show its discharging. Unit works fine from battery and from...
              08-02-2023, 03:45 AM
            • AdrenalinTL
              Another Dell not charging / PS_ID issue
              by AdrenalinTL
              This board is driving me crazy. So it's the usual AC Adaptor not detected in BIOS etc. Battery doesnt charge.
              Got a new charging pin, original Dell charger that works, another battery that also works. Still have an issue.
              Problem is I am very new to this so I need a very laymans way of explaining to me what I should check.
              Thanks Guys
              Edit : Board is a LA-J081P
              06-23-2024, 05:45 AM
            • SuperJames
              Dell G3 17 3779 Weird power cycling and shutdown/restart issue
              by SuperJames
              This one's a weird one, and still unsolved despite it having gone back to Dell once.
              Specs
              i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
              Backstory
              I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
              10-23-2023, 04:09 PM
