MacBook Pro 16" 2019 NAND Swap
  • Karmet
    • Dec 2022
    • 8
    I couldn't find a post related to this, so if it exists please point me in that direction.
    I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
    I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
    Thanks for your consideration and help!
    Karm
  • reformatt
    • Feb 2020
    • 1450
    Re: MacBook Pro 16" 2019 NAND Swap
    https://www.youtube.com/watch?v=yR7m...annel=iBoffRCC
    Covers it all pretty well. Apple have it all covered.
    Each set has firmware for the specific brand of NAND striped across them, hence why they need to be replaced in the same order when transplanted. If they are from a T1 system (and assuming that there is a firmware set for that NAND type for a T2), I'm pretty sure you need to put in that firmware first via external programmer. The T1 systems just treat the SSD like a regular one, as opposed to the T2 which are completely different.
    • Karmet
      • Dec 2022
      • 8
      Thanks. Yes, this is the go to video for NAND swap prep. I was hoping someone had attempted this with what I had on hand.
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        Hi here is it good video abouth nand swapping.
        Is not so easey butt gives you good indide what is going on.
        https://youtu.be/yR7m4aUxHcM
        Regards
        • Karmet
          • Dec 2022
          • 8
          Thanks for the help, and hopefully with combined efforts and knowledge we can keep these devices working way longer than Apple had ever intended. It seems they've built in planned obsolescence by using a striped RAID 0 to make their computers faster.
          • reformatt
            • Feb 2020
            • 1450
            It's almost criminal. The lengths that Apple goes to to prevent repairs and upgrades is not widely known amongst their user base. It makes a joke of any attempt by them to say they are environmentally friendly.
            At least with a dead system on a PC, we can remove the SSD and recover the data. Yet the iSheep keep buying Apple's crap which is built to fail from the factory.
            • Arshad alam4659
              • Aug 2020
              • 156
              • India
              can i replace iphone nand with macbook nand if both are differen i have jcid p15
              • ugamazing
                • Jun 2013
                • 171
                • usa
                Yes if you have a full proper set for the board you're installing on, and you write the correct dump to each nand and place properly, yes it will work. But you MUST confirm the same generation-nand chips between each device. Compare part numbers and go from there.
                • Arshad alam4659
                  • Aug 2020
                  • 156
                  • India
                  i have iphone 11 128gb tbs 3234 can i changed with (hynix hn3t0ba 128gb this chip was in m1 a2337 ) or toshiba (kic5224 256 gb this chip was in m2 a2681) and how to check genaration nand chip
                  • ugamazing
                    • Jun 2013
                    • 171
                    • usa
                    No, you cannot install nands that are of a different model than the ones native to the board. You will need to check and confirm the part-numbers of the nands on the 01700 board, then source those. They must be compatible with the controller in the T2.
                    • Arshad alam4659
                      • Aug 2020
                      • 156
                      • India
                      I HAVE PURCHASED tsb4227 128gb i think this chip will work perfectly
                      • ugamazing
                        • Jun 2013
                        • 171
                        • usa
                        Yes that's a supported chip, should work fine once programmed and properly positioned.
                        • tech_guru
                          Macbook Pro 2019 A2141 NAND Shorted
                          by tech_guru
                          Hello. If you could please help me understand what I am doing wrong...
                          This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
                          I also replaced the tps power ic for the ssd.
                          Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
                          08-28-2025, 08:04 AM
                        • cheebster
                          MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
                          by cheebster
                          Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
                          Nand voltages are missing.
                          I've found no shorts at all so far, no signs of heat via thermal camera either.
                          PPBUS_G3H 12.31
                          PP3V3_G3H_RTC 3.387v
                          PP3V3_G3H 12.31v
                          PP2v5_NAND_SSD0 0v 58 ohms
                          PP2v5_NAND_SSD1 0v 57.8 ohms
                          PP1v8_SLPS2R 1.8v
                          PP1v1_SLPS2R 1.1v
                          P3V3_G3H_SOCPMU 3.37v
                          PP0V9_SLPDDR 0.9v...
                          10-11-2023, 11:31 AM
                        • bouch
                          unlock macbook air A1932 2019
                          by bouch
                          hi
                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                          I need help or information?
                          Does anyone have the minat2 activator 1.4 software?
                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                          Thank yo...
                          03-12-2025, 10:14 AM
                        • kenzo2
                          Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                          by kenzo2
                          I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                          I need dump file MACBOOK PRO A2159
                          TSB4232(256)
                          TSB4229(256)
                          Thanks​
                          01-11-2025, 04:18 AM
                        • kuba2102
                          Macbook Air M2 A2681 NAND upgrade error 35
                          by kuba2102
                          Hello people. I have undertaken an upgrade from 256GB to 512GB. I have another A2681 board that I sourced NANDs, resistors and capacitors from. Yet when I try to restore the firmware in FDU mode I get the error 0x23 (35) (error formatting the NAND). Could it be the faulty NAND or I have missed something? Thank you...
                          07-03-2025, 12:20 PM
