compal_la-b162p_r1.0 does not start
    Hello. Brought a laptop ACER_Aspire_E5-571G with the stated malfunction does not turn on. We decided to clean the laptop ourselves, and after that the laptop does not turn on. Rather, the LED lights up for a few seconds and turns off. There are standby voltages, the bios was flashed with several firmware, the power button is relayed to the hub, but I found such a moment. The resistance on the foot is 100 multa PCH_RSMRST# 30ohm, when the power supply is connected, the voltage does not rise, 0.34 V appears when the button is pressed. When the 100 leg is raised, the resistance on the contact pad PCH_RSMRST# also remains 30 ohms, and 3.3 V appears on the foot of the multicontroller after pressing the power button. Diode d25, r117 is fine. Also, for some reason, 0.25V is present on the pl1002 throttle, there is no consumption on the lbp. There are no resolving signals to the pu1001 chip. Now with regard to the resistance of the 100 leg, and the understated resistance. Does this indicate a malfunction of the hub part of the combine, or did I miss something?
    Re: compal_la-b162p_r1.0 does not start
    I think you are right in your conclusion. RSMRST# should have atlest 10K resistance to GND.
