PLF/CSF 45W uma enabled
  • doctormasry
    • 98
    • giza
    i have toshiba L850 but motherboard id is PLF/CSF 45W uma dsc mb
    chip vga is bad
    i convert it to uma but i have problem with vga driver
    i install new windows np problem but when i install intel graphic driver restat and don't go to desktop again
    any help
  • Sephir0th
    • Oct 2020
    • 1262
    Re: PLF/CSF 45W uma enabled
    Maybe dGPU wrong diagnosed as being bad earlier or conversion not done properly, for example.
    FairRepair on YouTube
    • doctormasry
      • 98
      • giza
      i didconversion for plf/plr/csf/csr dsc mb model well
      no problem
      but with this model ( PLF/CSF 45W uma ) can't install intel graphic driver
      Have you converted to this model before?
      • ameesh.p
        • Dec 2014
        • 33
        • qatar
        chip vga is bad
        any help
        how you convert this? any link for refrence?
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
        • harp
          how to install old display driver in win10
          by harp
          It is time to upgrade my system, so I want to extend working surface with second monitor. The graphics card is Asus EN6600LE Silencer with 256MB, and have DVI and VGA output connectors. I try to find pure *.inf drivers (like in old days...), but nothing package beside a hundereds and hundereds MB instead... At last, downloading a last driver (148MB) from https://www.driverscape.com/download...eforce-6600-gt but in it, thre is no readme, install, setup or working inf file... So, nowadays is instalation hardware pass a new level of rocket science or I miss something? Pleas help if you have...
          06-04-2025, 12:40 PM
        • ongobongo
          Radeon RX 6700 XT chrash while driver install, memory PWM-Driver?
          by ongobongo
          Hi guys,
          I have a new project, a PowerColor RX6700XT GPU which starts up fine but crashes as soon as some load comes up, the driver install is enough for this. The install won't succeed and the card crashes with ramping fans.
          What I figured out so far:
          As the card starts up, all voltages are there.
          The core rails seem to work fine, all of them run at 500KHz (measured with a normal multimeter as I don't have an oszilloskop at hand).
          That said, I think I have a problem with one of the memory rails. The top two drMOS on the right side (see picture) power the memory....
          09-15-2023, 12:57 PM
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • Traptor
          Gigabyte GV-N960WF2OC-4GD black screen after driver install
          by Traptor
          Hi Guys,
          I have a Gigabyte GV-N960WF2OC-4GD card.
          I got his card in wrong state.
          Windows start normal mode and I got picture but after driver install I got only black screen. The PC is not freezing because I can reboot using keyboard.
          I tested the card with mats/mods and I did not recognize problem.
          for example the ./mats -e 20 got PASS.
          So, where can I find the problem?
          10-15-2023, 01:43 PM
