Macbook Pro A1706 820-00239-A 20v but not run
  • sdogs
    • Feb 2016
    • 86
    • Italy
    Hello everyone, I have a macbook pro 13 A1706 with the logic board that doesn't want to start.
    It has 20v input, very little absorption, it doesn't heat up, I don't know the story but it looks like it hasn't been worked on.
    I suspect the CPU may be dead, but I also have suspicions about the u7210 and U7800, I have checked the capacitors near the CPU but they don't appear to be damaged.
    what can i try? U7800 reballing? will it be the right way?
    I made the following measurements:
    PPBUS_G3H ---13V
    PPBUS_HS_CPU ---13V
    PPBUS_HS_OTH5V ---13V
    PPDCIN_G3H ---20V
    PP3V3_G3H ---3.3V
    PP3V3_G3H_SMC_ISNS ---3.3V
    PPVCC_S0_CPU ---0V
    PPVCCIO_S0_CPU ---0V
    PPVCCPRIMCORE_SUS_PCH ---0V
    PP1V8_SUS ---0V DIODO MODE ---0,28 ohm
    PP1V8_S4 ---1,8V
    PP1V8_S3 ---0V ---0,10 ohm
    PP1V8_S3_MEM ---0V ---0,10 ohm
    PP1V8_S0 ---0V ---0,32 ohm
    PP1V0_SUS ---0V ---0,02 ohm
    PP5V_S5 ---5V
    PP5V_S5 ---5V
    PP5V_S4 5V
    PP5V_S0 ---5V
    PP3V3_S5 ---3,3V
    PP3V3_SUS ---3,3V
    PP3V3_S5_T139 ---3,3V
  • mon2
    • 14238
    Re: Macbook Pro A1706 820-00239-A 20v but not run
    Review the power rails here:
    https://logi.wiki/index.php/Power_Rail_List#A1706
    • sdogs
      • Feb 2016
      • 86
      • Italy
      I checked following the binary listing, maybe I missed something? The problem seems to be related to PPVCC_S0_CPU and other binaries related to that sector.
      Excuse me but I don't have a great experience and I'm trying to understand better
      • mon2
        • 14238
        You may have a dead CPU fault. Remove all power. Meter in resistance mode.
        Check the resistance to ground of the following points of interest:
        PPVCC_S0_CPU
        PPVCCGT_S0_CPU
        PPVCCSA_S0_CPU
        • sdogs
          • Feb 2016
          • 86
          • Italy
          here are the measurements
          PPVCC_S0_CPU 3,3 ohm
          PPVCCGT_S0_CPU 1,2 ohm
          PPVCCSA_S0_CPU 1,3 ohm
          what do you think about it? Do you think the cpu isn't doing very well?
          thank you very much for taking the time to me ;-)
          • mon2
            • 14238
            reference:
            https://boards.rossmanngroup.com/thr...v-0-25a.59321/
            One meter probe to PPBUS_G3H; other meter probe to PPVCC_S0_CPU.
            What is the measurement?
            • sdogs
              • Feb 2016
              • 86
              • Italy
              it doesn't have a constant value, it seems to drop to settle at about 13k ohms
              • Danielreinaa
                HELP need password bios Macbook A1706
                by Danielreinaa
                Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                09-07-2024, 03:47 PM
              • capon5153
                Macbook A1706 works perfectly but no data on USB C
                by capon5153
                hello,
                so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                06-22-2025, 09:42 AM
              • B2L_Repairs
                Macbook A1706 touchpad and keyboard not working. Please help
                by B2L_Repairs
                Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                10-09-2023, 04:56 AM
              • obelix24
                A1706 - Macbook pro - one USB-C port only 20V 0A
                by obelix24
                I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                There were some broken pads under CD3215 but i've recreated them.
                What should be...
                05-22-2024, 08:04 AM
              • johnbeton
                Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                by johnbeton
                I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                This is what I measure so far:
                Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                PPBUS_G3H = 0,79v
                PPBUS_HS_CPU = 0,79v
                PPBUS_HS_OTH5V = 0,79v
                PPBUS_HS_OTH3V3...
                05-21-2024, 02:06 PM
