HP Pavillion 15-cw1077nl no power
  • vpower
    • Sep 2022
    • 116
    • italy
    Hi, I have this laptop that is not powering on. It died suddenly. If I connect the charger or the power supply (19v), no charging led light is turning on.
    I only checked with a multimeter that 19v is on the connector of the charging cable on the board (marked with an arrow on the "front" image).
    Any hint? Cannot find any schemathics or board layout. Board code is DAG7BJMB8C0 REV C MODEL G7BJ
    Regards,
    Vito
  • mon2
    • Dec 2019
    • 14662
    Re: HP Pavillion 15-cw1077nl no power
    Locate the power adapter connector. Start there to confirm the adapter voltage is present.
    Continue to review the power path to the 2*DCin mosfets. These will be 8 pin devices.
    Measure with care the voltage to ground of:
    Source (1-2-3)
    Gate (4)
    Drain (5-6-7-8)
    Pins of each of these mosfets. Post the measurements and also the topside markings of the mosfets.
    Next, these mosfets are enable by the gate pin that will contain a ~4k resistor to the charger IC. The charger IC will be square in shape = qfn package.
    What are the topside markings of the charger IC?
    Do post pics of the mosfets and the charger IC for a verification.
    • vpower
      • Sep 2022
      • 116
      • italy
      Source (1-2-3)
      Gate (4)
      Drain (5-6-7-8)
      the adapter voltage is present, around 20 volts, "power adapter connector" image
      I marked all the mosfets I found in front and rear of the board, I will check voltage on all of them and report here.
      I attached an image of battery connector, can you help me locating the charger IC?
      • vpower
        • Sep 2022
        • 116
        • italy
        I could only locate 2 classic mosfets, one on the front side and one on the rear side.
        front side:
        source(1-2-3) 0.4v
        gate (4) 0.3v
        drain 0v
        rear side
        source 0v
        gate 0.2v
        drain 22v
        • mon2
          • Dec 2019
          • 14662
          The charger IC is the square on marked BQ738H.
          The part is a custom marked version with little public information. However we can get what we need from here and comparing to other similar parts from Texas Instruments.
          https://www.datasheetcafe.com/bq2473...ge-controller/
          With care, meter in dc volts mode, measure the voltage to ground of the VCC pin on the charger IC.
          Also interested in the following:
          REGN
          ACDRV
          ACOK
          Post each measurement.
          • vpower
            • Sep 2022
            • 116
            • italy
            here the measurements:
            VCC 21.1v
            REGN 6.9V
            ACDRV 0.1V/0.2V
            ACOK 0V
            • mon2
              • Dec 2019
              • 14662
              So the chip is being powered.
              ACDRV is not a good voltage. It should be ~25 volts to enable the DCin mosfets.
              ACDRV 0.1V/0.2V
              ACOK 0V
              Check the voltage of ACDET. This is a voltage that is built by 2 resistors to lower the adapter voltage to a safe voltage for the charger IC. If the voltage on this pin is above ~2v7 then the adapter is deemed to be suitable and connected to power the laptop.
              • vpower
                • Sep 2022
                • 116
                • italy
                ACDET is 3.1v
                • mon2
                  • Dec 2019
                  • 14662
                  This is a good value.
                  Remove all power. Meter in diode mode. Touch your meter probes and you will hear a tone beep.
                  Now one probe to ACDRV pin, other to nearby black resistor parts. If you hear a tone, stop. This is the 4k resistor in series with the ACDRV pin.
                  Continue to locate the mosfets as follows.
                  Meter probe on the other side of this same resistor.
                  Other probe to pin #4 of any local mosfet. If you hear a tone beep, stop. This is one of your 2*DCin mosfets.
                  Identify the mosfets and share an updated picture.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Mita99
                    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                    by Mita99
                    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                    04-27-2025, 07:20 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
