Hp 470 G2 not turn on
  • arber1232
    • Dec 2019
    • 368
    • Albania
    Hi everyone
    I have hp 470 g2 not turn on zpl40/50/70
    when i put charcher dc jack flashing orange light for 2 second and off
    i check voltage i have 19.5 v and ADP_SIGNAL is 3,3v
    i check first mosfet for shorts is ok
    In bios i have 3.4v in pin 6 and 7
    Can i help me ?
  • mon2
    • Dec 2019
    • 14106
    Re: Hp 470 G2 not turn on
    Measure the voltage to ground of each pin of the 2*DCin mosfets.
    Interested in the
    Source (1-2-3)
    Gate (4)
    Drain (5-6-7-8)
    Pin voltage measurements. Repeat for the 2nd DCin mosfet. Post all measurements.
    • arber1232
      • Dec 2019
      • 368
      • Albania
      Pq101
      source=19,5v
      gate=6.1v
      drain=19.5v
      pq102
      source=19.5
      gate=25v
      drain=19.5v
      • mon2
        • Dec 2019
        • 14106
        Post pics or topside markings of these measured mosfets.
        Wish to confirm if one is a P-channel and the other is a N-channel type.
        • arber1232
          • Dec 2019
          • 368
          • Albania
          do you need schematic ?
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Originally posted by arber1232
            Schematic ---> https://www.badcaps.net/forum/showth...633#post678633
            Become a Badcaps supporter
            Thanks to all supporters.
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • robante15
              Acer Aspire 4520 won't turn on after reboot
              by robante15
              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
              If I remove the...
              04-06-2024, 06:50 PM
