Macbook pro A1278 820-2936 No light/turn on
  • Adogabriel100
    knowledge seeke
    • Aug 2021
    • 36
    • peru
    Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
    History:
    this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
    A month later comes back again and has the actual problem (no green/orange light and dont turn on)
    The macbook can turn on with only the battery connected but in fact, dosent charge.
    Voltajes:
    PP3V42_G3H = 3.3v
    PPBUS_G3H = 12.2V
    PM_PWRBTN_L = 3.4V
    PCH_SRTCRST_L = 3.4V
    RTC_RESET_L = 3.4
    PCH_INTRUDER_L = 3.1
    PCH_INTVRMEN = 3.2
    PCH_DSWVRMEN = 3.2
    PP3V3_S5 = 0V
    PP5V_S5 = 0V
    PM_DSW_PWRGD = 0V
    SMC_ADAPTER_EN = 0V
    isl 625 (U7000):
    (CHGR_AGATE) pin 1 = 0v
    (CHGR_DCIN) pin 2 = 19.4v
    (CHGR_ACIN) pin 3 = 4.7v
    (CHGR_VFRQ) pin 4 = 3.4v
    (CHGR_ICOMP) pin 5 = 1.2
    (CHGR_CELL) pin 6 = 3.4
    (SMBUS_SMC_BSA_SDA) pin 10 = 3.3v
    (SMBUS_SMC_BSA_SCL) pin 11 = 3.3v
    (PP3V42_G3H) pin 12 = 3.3v
    (CHGR_RST_L) pin 13 = 3.3v
    (SMC_BC_ACOK) pin 14 = 0.6v
    (CHGR_CSO_N) pin 17 = 12.2v
    (CHGR_CSO_P) pin 18 = 12.2v
    (PP5V1_CHGR_VDD) pin 19 = 5v
    (PP5V1_CHGR_VDDP) pin 20 = 5v
    (CHGR_PHASE) pin 23 = 12.2v
    (CHGR_UGATE) pin 24 = 12.7v
    (CHGR_BOOT) pin 25 = 16.5v
    (CHGR_SGATE) pin 26 = 19.1v (i think that this one has to be 0v in order to enable)
    (CHGR_CSI_N) pin 27 = 19.4v
    (CHGR_CSI_P) pin 28 = 19.4v
    ¿Do i need first PP3V3_S5 - PP5V_S5 to have a U7000 funcional?
    dont know what im missing on this
    i appreciate your help.
    really thanks in advance.
  • mon2
    • Dec 2019
    • 14575
    Re: Macbook pro A1278 820-2936 No light/turn on
    PP3V42_G3H = 3.3v
    >> Start with this one, it should be 3v42.
    What is the input voltage to this regulator?
    Then, remove all power. Check the resistance of the feedback resistors used by this regulator. Do not power on while checking resistance and do not power on if these parts are removed.
    • Adogabriel100
      knowledge seeke
      • Aug 2021
      • 36
      • peru
      i'm sorry. i was measuring with my cheap multimeter
      PP3V42_G3H = 3.44v
      PPBUS_G3H = some times get 12.22 and 12.55
      input voltaje on U6990 (3.425V "G3Hot" Supply)
      from D6990 PPVIN_G3H_P3V42G3H to pin 7 of U6990
      PIN 7 (VIN) = 19.77v
      R6990 = 46.5 Ohms
      R69951 = 0.85 Mohm
      • mon2
        • Dec 2019
        • 14575
        SMC is waffling.
        Remove the fuse on this line @ F7040.
        Then power up again and check the voltage to ground at F7040, pin #1 (producer side).
        What is the voltage measurement?
        Next, power down, meter in resistance mode.
        Measure the resistance to ground of F7040 PCB pad, pin #2 (consumer side).
        What is the resistance mode reading ?
        • Adogabriel100
          knowledge seeke
          • Aug 2021
          • 36
          • peru
          Thanks for the help, mon2.
          F7040, pin #1 (producer side). = 12.24v
          F7040 PCB pad, pin #2 (consumer side). = 360kohms
          • mon2
            • Dec 2019
            • 14575
            Is this voltage stable or fluctuates upto 12v55 ? The resistance to ground reading is ok and there is no short on the PPBUS_G3H rail.
            The voltage of PPBUS_G3H is configured using the SMBUS (SCL & SDA) lines by the SMC. The same SMBUS interface is shared by the battery back's BMS (battery management system). If either the SCL or SDA line is shunted due to a transient event, then all communication will halt.
            Carefully measure the voltage to ground of the following points of interest:
            SMBUS_SMC_BSA_SCL
            SMBUS_SMC_BSA_SDA
            Post the measurements.
            • Adogabriel100
              knowledge seeke
              • Aug 2021
              • 36
              • peru
              Is this voltage stable or fluctuates upto 12v55?
              The voltaje just stay stable, 12.24v
              SMBUS_SMC_BSA_SDA = pin 10 = 3.44v stable on pin 10 of u7000
              SMBUS_SMC_BSA_SCL = 3.44v stable on pin 11 of u7000
              • mon2
                • Dec 2019
                • 14575
                What is the voltage to ground of SMC_RESET ?
                • Adogabriel100
                  knowledge seeke
                  • Aug 2021
                  • 36
                  • peru
                  SMC_RESET = 3.25v
                  • mon2
                    • Dec 2019
                    • 14575
                    This is a good value.
                    Remove all power. Meter in diode mode. Touch your meter probes and confirm the tone beep.
                    Then one meter probe on the
                    SMBUS_SMC_BSA_SCL
                    And other meter probe to the closest point of the smc chip for the same trace. Do inspect for any corrosion.
                    Repeat for:
                    SMBUS_SMC_BSA_SDA
                    Want to confirm the SMbus traces reach their destination. The SMC chip is the SMbus master and the ISL chip is the smbus slave. If there is a broken trace, the voltage cannot be boosted for ppbus_g3h.
                    • Adogabriel100
                      knowledge seeke
                      • Aug 2021
                      • 36
                      • peru
                      there is not close test point or IC close to the SMC to check continuity. either way. i check the points and every point does its beep.
                      i check for corrosion (under microscope) and looks normal.
                      • mon2
                        • Dec 2019
                        • 14575
                        What is the voltage to ground of ALL_SYS_PWRGD ?
                        • Adogabriel100
                          knowledge seeke
                          • Aug 2021
                          • 36
                          • peru
                          ALL_SYS_PWRGD = 0v
                          • mon2
                            • Dec 2019
                            • 14575
                            What is the voltage to ground of SMC_BC_ACOK ?
                            • Adogabriel100
                              knowledge seeke
                              • Aug 2021
                              • 36
                              • peru
                              SMC_BC_ACOK = 0.69
                              some times the macbook turn on (im using BY-3200) and when i disconect the cable just dont turn on again.
                              i already change the U7000 and the SMC (before ask for help) and got the same behavior.
                              the u7000 from a know working board (yes, just for test) and the SMC from a donnor board.
                              • mon2
                                • Dec 2019
                                • 14575
                                That is too low.
                                What is the voltage to ground of CHGR_ACIN ? Measure @ between R7010 & R7011. Post the measurement.
                                Remove all power. Meter in resistance mode.
                                Measure the resistance to ground of SMC_BC_ACOK. If the resistance is too low, this can cause this signal line to be with a low voltage.
                                Next, locate R5087. Check the resistance of this part across the 2 sides of the resistor. Is it ~470k ohms ? This resistor is required to pull-up the signal line to park to 3v42.
                                Next, meter in voltage mode. Confirm the voltage to ground on each side of the same resistor @ R5087. One side must be ~3v42.
                                • Adogabriel100
                                  knowledge seeke
                                  • Aug 2021
                                  • 36
                                  • peru
                                  SMC_BC_ACOK = 400 Kohms
                                  R7010 pin 1(PPDCIN_G3H) = 19.98 / PIN 2 (CHGR_ACIN) = 4.73v
                                  R5087 = 415k ohms (measurement before taking it out of board)
                                  R5087 pin 1(SMC_BC_ACOK)= 3.07v / pin 2(PP3V42_G3H)= 3.44v. (measurement after put another resistance)
                                  OKAY. now... this happens; I take out R5087 from the board to measure the resistance. next thing. it blow from my tweezers. i put another one and the macbook it's turning on without any problem again (at least for now).
                                  im not sure if that was the problem. maybe was the heat that i apply under SMC? really dont know. hope that this macbook dont come back
                                  now im going to test it and see what happen.
                                  thanks again for your time and help mon2. i really appreciate
                                  • mon2
                                    • Dec 2019
                                    • 14575
                                    Awesome! See, that is a good omen for the resistor to fly away. This line was low and this resistor is needed to pull it high. Perhaps a bad solder joint. Run YouTube videos to stress test it. Hope it is stable for you. Reflowing the SMC is one of the suggestions for such cases.
                                    • Adogabriel100
                                      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                      by Adogabriel100
                                      Hey! This is a A1278 macbook 2011.
                                      Problem: Not turning on / No green light
                                      Im using by3200s charger.
                                      Voltajes:
                                      PPBUS_G3H = 12.26v
                                      SMC_RESET_L = 3.3v
                                      PP3V42_G3H = 3.42v
                                      U7000 =
                                      Pin 1 CHGR_AGATE = 0v
                                      Pin 2 CHRG_DCIN = 19v
                                      Pin 3 CHRG_ACIN = 4.6v
                                      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                      Pin 12 PP3V42_G3H = 3.42v
                                      Pin 13 CHRG_RST_L = 3.3V
                                      Pin 14 SMC_BC_ACOK = 0.8V
                                      Pin 19 PP5V1_CHRG_VDD = 5.05V
                                      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                      04-01-2024, 01:02 PM
                                    • Rezendes
                                      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                      by Rezendes
                                      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                      05-10-2024, 02:18 PM
                                    • pcbmaniac
                                      MacBook A1278 (3115) No PPBUS_G3H Issue
                                      by pcbmaniac
                                      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                      1. U7000 Measurements:
                                        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                      2. Resistors:
                                        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                      • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                      12-02-2024, 04:12 PM
                                    • sizar00740
                                      macbook pro 13 inch a1278 820-2879
                                      by sizar00740
                                      please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                                      07-30-2025, 10:21 AM
                                    • envym
                                      MacBook Pro 2018 with Activation Lock
                                      by envym
                                      Hi everyone!
                                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                      06-27-2025, 08:54 AM
