[help]a1706! touchbar dead and fans at full speed
  • phantomEVO
    • Mar 2013
    • 508
    hi guys i have a 1706 liquid spilled
    motherboard 820-00923
    some one has changed keyboard after liquid spill
    problem is that touch bar is totally dead, fans at full speed as soon as i power on the notebook and macbook ultra slow and tons of errors on apple diagnostic
    then i've found that resistor r5860 was miss
    now macbook works very fast but still no touch bar and fans at fool speed. i've tried another touchbar with no luck
    istat and tgpro say there is no problem, all sensors ok
    apple diagnostic give me 2 codes ppf003 and ppf004
    any hint?
    thank you
  • mon2
    • 14659
    Re: [help]a1706! touchbar dead and fans at full speed
    https://www.ifixit.com/Answers/View/...or+Code+PPF003
    • phantomEVO
      • Mar 2013
      • 508
      Sorry But i don't find the answer 😪
      • mon2
        • 14659
        It was the fan connector in this case that was linked.
        Carefully review the same SMD fan connector. Remove the flex cable and check the contacts on the thin fan cable. Suggest to use IPA / costco pharmacy grade to clean the contacts. Then seat it back again for testing.
        Fan at full speed is also often linked to the trackpad. Is the trackpad attached or removed? Sensors are present in the trackpad that may not be working.
        • Arshad alam4659
          macbook a1706 in dead condition
          by Arshad alam4659
          today i received a macbook a1706 in dead condition When I removed the battery the laptop started up i connect the battery again and press power button but laptop not turn on
          I did smc reset and the laptop started . I have to reset the SMC every time to turn it on. It does not turn on without resetting the SMC. Sometimes it starts without resetting the SMC.
          someone guide me what is the problem bad smc or anything
          12-19-2024, 02:41 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • saronno
          Macbook a1706, dead keyboard.
          by saronno
          Anyone has experience troubleshooting keyboard on this model?
          From schematics it seems an i2c keyboard, the problem is I can't find a good test point con scl and sda, in order to see if voltage is present (usually i2c works with the 2 rail pulled up with a resistor to a voltage source ... components attached to the two rail communicate pulling the line down.
          05-30-2025, 08:06 AM
        • baglaivlad
          Apple MacBook Pro A1706 CPU hot, but signs of life
          by baglaivlad
          Hi everyone. Got MacBook Pro 13 2016 A1706 w/ Touchbar (820-00239) with strange symptoms. It draws 20V/1A from the charger (w/o battery connected), CPU gets reasonably hot, the fans start spinning (when the CPU reaches some temp threshold), but no image, no sound, no backlight, no touchpad clicks, no keyboard backlight (also no response to CapsLock press), no image on external display (through working dongle and HDMI). The laptop chargers the battery with no issues. Also the laptop reacts to power button like it should be: it kinda "turns on" (the fans start spinning) when on battery...
          09-25-2022, 06:22 PM
        • kurtspirit
          Macbook A1706 EMC3071 (2017 Touchbar)
          by kurtspirit
          I have a Macbook Pro 2017 Touchbar (A1706) that suddenly shut down for no reason.
          So I took it apart and started measuring.
          The PP3V3_G3H seems problematic. I traced the line to component U6903 and on Pin 10, I measured 1.9V instead of 3.3V.
          Unfortunately, my skills stop there and I don't understand where this type of failure can come from.
          I saw on videos of repairers that the failure could come from the U7000 component which would be at the origin of the 3.3V but they have absolutely no voltage. I have a 1.9v...
          What do you think ?...
          08-23-2022, 05:57 AM
