A1708 820-00840-01 20V 0.94A no Power
  • isa198585
    • Feb 2020
    • 71
    • austria
    Measures :
    PPBUS_G3H 13V
    PPDCIN_G3H 20V
    PP5V_S5 3 to 5V not stabil
    PP3V3_S5 1 to 3V not stabil
    PP3V3_G3H 3,40V
    After I removed I removed Charger and Battery, and measured the resistance to ground.
    PP5V_S5 1,500M
    PP3V3_S5 0,040M ( not stabil, goin up slowly)
    voltage to ground without connected Battery
    P3V3S5_EN 3.3V
    P5VXX_EN 0.00V
  • isa198585
    • Feb 2020
    • 71
    • austria
    Re: A1708 820-00840-01 20V 0.94A no Power
    L7030 1,34v
    q7030 ppdcin_g3h_chgr 20v
    q7040 ppvbat_g3h_chgr_reg 13v
    • mon2
      • Dec 2019
      • 14231
      Remove all power. Meter in resistance mode.
      Confirm the current loop resistance between pins:
      CSP1 (pin 7)
      CSN1 (pin 8)
      Measure directly at the IC (U7650).
      • isa198585
        • Feb 2020
        • 71
        • austria
        resistance between pins: 7 and 8 on U7650 1.604
        • mon2
          • Dec 2019
          • 14231
          It is the correct value.
          • isa198585
            • Feb 2020
            • 71
            • austria
            what can I do more?
            there someone write me, that I have to check shurt on PPVCCPCH_S5G
            Any Idea how to check this?
            • mon2
              • Dec 2019
              • 14231
              Do not short anything.
              Review this Korean website on your phone. Then phone will auto translate to English.
              Keep this thread updated with your progress.
              https://m.blog.naver.com/PostView.na...&proxyReferer=
              • isa198585
                • Feb 2020
                • 71
                • austria
                I found something, what I can't explain. When I connect my power supply to USB-C port 1, I get 20V on fuse F3000 and at the same time 12V on fuse 3010, and that's wrong, I tested that on a working board, also when I connect my power supply to USB-C port 2 so I get 20V on F3010 and 0V on F3000.
                And thank you for the Korean website, it helps me a lot. I'll take a closer look. If you think of anything, please write to me
