macbook pro 820-3462 charges very slowly
  • donnos
    • Sep 2016
    • 11
    • Malaysia
    Received a macbook pro which in notification shows 7 or 10 hours until full during charging.
    have replaced ISL6259 and Q7055 and still getting same results. current sensing resistors measured fine @ 0 and 2ohms. what else could be the issue?
    without battery i get 12.58V. i have physically shorted Q7055 drain to source to rule out issue with the mosfet and can confirm its still the same. any suggestions?
    when i shutdown it charges at only 16.5v 0.5A. during boot PSU draws 2.5-3A suggesting it momentarily charges but drops to 1.5A power draw after boot.
  • mon2
    • 14677
    Re: macbook pro 820-3462 charges very slowly
    Confirm the voltage to ground of:
    SMBUS_BATT_SCL
    SMBUS_BATT_SDA
    • donnos
      • Sep 2016
      • 11
      • Malaysia
      both Diode reading are 0.4 red on ground
      • mon2
        • 14677
        Ok. Post the DC voltage to ground of the same. Meter in DC volts mode (10v or higher is ok). Wanting to confirm the SMBUS lines for this segment are ok.
        Also, remove all power and meter in resistance mode.
        Measure directly at U7000 pins for the resistance between CSOP and CSON. Had this exact case last year and it took ~3 weeks to resolve. The fault was that the current sense loop was broken. The fault was only caught after a direct probe at the U7000 IC pins.
        It is important to check that this current sense loop is ~2 ohms (pin 17 & 18 of U7000).
        • donnos
          • Sep 2016
          • 11
          • Malaysia
          SMBUS lines are 3.34v
          CSON to CSOP resistance is 3ohms.
          • donnos
            • Sep 2016
            • 11
            • Malaysia
            issue resolved by replacing SMC
            • itsmeapple
              MacBook Pro Charges When Off, But Not When On (MBP 2014 15 Inch) 820-3662-A
              by itsmeapple
              I'm facing an issue with my MacBook Pro.
              When it's switched off, it charges while the battery is connected. However, when it's powered on, the charging stops after a few seconds.
              Another strange thing is that when I disconnect the battery and plug in the charger, the MacBook Pro turns on and runs without any issues.
              I've already tried using a different OEM charger, but no luck. I even swapped the charging port DC-IN, but the problem persists.
              Has anyone else experienced this issue before?
              Thank you!...
              02-21-2025, 02:22 PM
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
