is it possible restore data from the hdd with removed rom ic?
  • harp
    • Jun 2022
    • 606
    • Planet Earth
    is it possible restore data from the hdd with removed rom ic so, is there any way, theory or practice, to restore or calculate missing data in flashrom ic from actual data stored on disk platers? In other words, is data on disc somehow reachable, recover without original rom firmware, using exactly donor board, special lab hardware, etc?
  • truclacicr
    • Apr 2019
    • 321
    • australia
    maybe, it depends
    • harp
      • Jun 2022
      • 606
      • Planet Earth
      Yes, indeed, thank you!
        • Jul 2011
        • 6041
        The only successful thing I have done in the past for drive that is not recognize by the motherboard is is to find another drive that has a board that is recognized by the motherboard and see if it can be read by it successfully about 40% of time has been my experience
        But the model numbers have to match the size of the drive has to match and the boards must match the closer you match the production date the better
        • truclacicr
          • Apr 2019
          • 321
          • australia
          If you have a specific HDD model in mind, then an answer can be better targeted. The question, as it stands, is unanswerable. I suggest that HDD Guru or HDD Oracle would be more appropriate places to research this subject. Depending on your location on Planet Earth, Ru.Board may be another option.
          • harp
            • Jun 2022
            • 606
            • Planet Earth
            Nothing specific... I just wonder if the present of rom ic has any impact on data safety, if is desired to save all other hardware resource of hdd.......... we can see that method removing or wipeing rom ic it not safe, beside some claims that rom ic hold "esenciall and unique" data required to function...
            • truclacicr
              • Apr 2019
              • 321
              • australia
              My understanding is that most Seagate HDDs since 7200.11 cannot be recovered if the ROM is missing. Also, no (?) Toshiba HDD is recoverable without the original ROM.The current firmware architectures have additional complications related to security.
              • welcometoo
                acer nitro 5 AN515-55 no display / caps lock
                by welcometoo
                Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                model: nitro 5 an515-55
                motherboard part number: GH51M LA-K862P Rev: 1A
                i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                i flashed new bios also ec(ene kb9022) the same result .
                disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                07-05-2025, 11:11 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • kingiii
                Possbility of data recovery, is it true?
                by kingiii
                Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
                07-02-2025, 02:29 PM
              • mscottdoran@gmail.com
                Can anyone identify the classification of this data signal?
                by mscottdoran@gmail.com
                Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                The boards are powered by a ground referenced...
                02-08-2025, 11:31 AM
              • Joe24
                Maytag Whirlpool Kenmore clothes dryer data bus
                by Joe24
                Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                I've been over the board looking for...
                01-13-2025, 06:50 PM
