Nm-a273 battery not detecting
  • ahmarzo
    • Mar 2015
    • 173
    • india
    Have a motherboard nm-a273 showing battery not detected,have replaced th battery and charging ic bq737.the sda and scl voltage is 3.3v and tracks to the io is proper.the laptop is powering on the battery and battery is charging when connected with adapter but showing no battery detected in windows
  • mon2
    • 14672
    Re: Nm-a273 battery not detecting
    Are the tested batteries known good units? They function in another logic board of the same model?
    Do you see activity on the SMBUS SCL / SDA lines? The pull-up voltage is a quick check to see if the SMBUS lines are not stuck but the test does not validate if there is communication on the same pins.
    Ideally, a logic analyzer or scope can be used to confirm the communication is ongoing.
    Do confirm that the same 3v3 on the SDA/SCL lines is present upto and including the battery connector / cable BMS interface on the battery pack.
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
    • trepachka
      iPad Air A1475 Boot loops after replacing battery
      by trepachka
      This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
      The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
      I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
      11-08-2024, 03:17 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
